I have an early Smiths magnetic type temperature gauge fitted in our Mini. This is the sort that does not use the voltage stabiliser. It has the correct early type sender unit fitted. However it is tending to read a high temperature once the engine gets up to temperature. The engine does not appear to be running too hot, so I wondered whether it is possible to adjust the gauge so that it reads slightly lower. I suspect that this could be due to using the 82 or 88 degree thermostat rather than the earlier 75 degree item.
The photos show it in all its glory!
Edited by Dartmoor Paul, 23 August 2015 - 08:03 AM.
