Hello, I have a 1992 British Open Classic Mini which usually drives great. However, when starting the vehicle from cold I experience a loss of power when revving the engine whilst stationary (the revs drop right down to the point where it would stall). Perhaps worth noting that when starting it idles very low (approx. 500rpm) which I usually correct by applying a little choke until the engine has warmed up- is this normal? Once there is some heat in the engine it operates normally, idles at about 1000rpm and experiences no loss of power when accelerating.
Hopefully I've explained the problem clearly but happy to elaborate if more information is required. Thanks in advance, Ben.
