How Do I Tighten This Ball Joint? (Pic Included)
suspension
23 replies to this topic
#1 Mok0m
Mok0m
  • 15 posts
Posted 28 October 2015 - 04:53 PM
So, I'm currently preparing to move my mini to another garage but before I can do that I wish to tighten up the front suspension to avoid turning my car into a lowrider. However, the little buggers don't want to comply and every time I turn the nuts the whole thread + ball joint turn with it. I gave it a good whiff of WD-40 to no avail.
Here is a picture of the culprit.
post-106375-0-22560400-1446051039_thumb.
Some help would be largely appreciated. :)
Edited by Mok0m, 28 October 2015 - 04:54 PM.
#2 GraemeC
GraemeC
  • 7,315 posts
Posted 28 October 2015 - 05:02 PM
Put a jack under the lower arm and use it to push the arm further onto the taper of the ball joint.  With some pressure applied it should stop the shaft from turning.
#3 Batmini
Batmini
  • 378 posts
Put a jack under the tie-rod and put a bit of 'weight' on the ball joint- ha ha beat me to it
Edited by Batmini, 28 October 2015 - 05:03 PM.
#4 olly33
olly33
  • 758 posts
  • Local Club: 42nd Street (back in day)
Posted 28 October 2015 - 05:06 PM
Have you tried putting some weight on it by lowering it onto the arm with jack or axle stand and try tightening it. If not perhaps it needs a new one,mine currently will not torque up properly.
#5 Mok0m
Mok0m
  • 15 posts
Would you recommend lifting it with a vertical jack?
#6 olly33
olly33
  • 758 posts
Posted 28 October 2015 - 05:07 PM
Same here,ha ha.
Cannot see why not
#7 GraemeC
GraemeC
  • 7,315 posts
Posted 28 October 2015 - 05:09 PM
I don't understand - what do you mean by a 'vertical' jack?
#8 Mok0m
Mok0m
  • 15 posts
Posted 28 October 2015 - 05:13 PM
http://i00.i.aliimg....raulic_jack.jpg
#9 Mok0m
Mok0m
  • 15 posts
Posted 28 October 2015 - 05:18 PM
So I went to try this lifted to the point where the car started lifting from the jack stands, and I went to tighten, still the same problem. Am I doing something wrong?
#10 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 28 October 2015 - 05:27 PM
Pull the threadd section out of the hole & clean off all the lubricant so both the pin & hole are dry. Put it back together. Put weight on the suspension so the pin is rammed into the hole & try again. You might try a few mild hammer blows on the back of the joint to further push the pin in the hole.
#11 olly33
olly33
  • 758 posts
Posted 28 October 2015 - 05:46 PM
The threads not stripped is it?
#12 Icey
Icey
  • 1,493 posts
Posted 28 October 2015 - 06:43 PM
If its still spinning with weight on it you'd be better off replacing it. That said, do give the threads a good clean out first.
#13 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 28 October 2015 - 07:25 PM
put some weight on it :D
#14 gazza82
gazza82
  • 2,919 posts
  • Local Club: TMF+
Posted 28 October 2015 - 08:26 PM
Bottle jack ...
#15 Cooperman
  • 23,039 posts
Posted 28 October 2015 - 08:49 PM
Jacks are usually 'vertical' as they lift things from the ground ;D .
Also tagged with one or more of these keywords: suspension
