#16
Posted 28 October 2015 - 09:44 PM
Obviously there was a language/translation barrier but the OPs picture cleared up what he meant.
#17
Posted 28 October 2015 - 09:48 PM
#18
Posted 28 October 2015 - 10:47 PM
#19
Posted 28 October 2015 - 11:29 PM
Also you will need a split washer on there. As often the nut will bottom out on the thread before it is tight.
So nut off. Arm down. Clean the threads. Check nut goes on cleanly. When it dies. Re fit arm. Washer and nut. Then apply pressure to the arm to grip th taper. Tighten the nut.
#20
Posted 29 October 2015 - 09:50 AM
With the weight on on suspension you should be able to turn the nut some rounds with your fingers. If that fails than the thread or nut is unusable anylonger and should be replaced.
#21
Posted 29 October 2015 - 06:09 PM
Don't cross thread the nut for a start would be a good beginning!
#22
Posted 01 November 2015 - 01:59 PM
So, I cleaned the thread and the nut has manged to slide in more but as nicklouse said the thread is gone. :/
I only need it to hold on for a couple of blocks on the back of a tow truck to take it to my other garage where I will be stripping it down for sandblasting. Think it should hold, right?
#23
Posted 01 November 2015 - 03:19 PM
But I would add a few washers so that you can actually get the tapers to lock when the nut is tightened as far as you can.
#24
Posted 02 November 2015 - 06:54 PM
If you are not driving it you will be fine.
Tks for the tip :)
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
