1275 A+ Fitted In Mk1 Shell - Carb Removal
engine
7 replies to this topic
#1 JamesC
JamesC
  • Just Joined
  • 125 posts
Posted 30 January 2016 - 04:21 PM
Hi there
I have a 1966 MK1 Super Deluxe fitted with what I now believe to be a 1275 A+ Metro block, as I have been working with the carburettor and ignition system.The engine has an electronic ignition (Metro distributor cap).
I am having trouble removing the SU carburettor (mounted on a Mini Sport inlet manifold) from its mounts because of the bulkhead. Is there a trick to removing the carburettor from its mount? Can someone advise?
James
#2 David128
David128
  • 644 posts
Posted 30 January 2016 - 04:30 PM
Try removing engine steady or steadies and tip engine slightly you may have to release exhaust clamp
#3 pdaykin
pdaykin
  • 587 posts
Posted 30 January 2016 - 04:51 PM
I normally remove to inlet manifold with the carb still attached
#4 Craig89
Craig89
  • 600 posts
Posted 30 January 2016 - 06:28 PM
I do the same, remove it together with the manifold. Sometimes the carb to manifold nuts have to be loosened in order to wiggle it all out
#5 GraemeC
GraemeC
  • 7,440 posts
Posted 30 January 2016 - 06:57 PM
And remove the rear inlet elbow
#6 JamesC
JamesC
  • Just Joined
  • 125 posts
Posted 31 January 2016 - 07:09 PM
Thank you for the very quick replies, I will take a look next time I'm in the garage.
#7 RHDmini74
RHDmini74
  • 167 posts
Posted 31 January 2016 - 07:38 PM
I was just doing this the other day. Take off the carb and manifold together, its easier. take off the 4 nuts that hold on the inlet manifold and center exhaust manifold and it should come right off.
#8 Alex_B
Alex_B
  • 4,573 posts
Posted 31 January 2016 - 08:23 PM
If you still struggle then remove the manifold studs and that will allow you to lift it straight up rather than fighting the studs.
