Hello again Mini-peeps, it`s meeeeeeeeee-ee. Thought I`d have a go at the 1380 started today as it is such a lovely day. I set piston 1 at tdc on the comp stroke and moved the dizzy so that the rotor was pointing at plug lead 1 to give me a reference as there are no timing marks on my crankshaft pulley. I reconnected a wire that had pulled out of its end-piece and squirted some easy start down the carb. Gave him a boost from my daily car, turned the engine over and......................BANG! out of the exhaust (the easy start) followed by silence. I cranked him again but there was a marked reluctance to do anything. I have attached some pics which are not too good as there is so much other stuff in the way, but can any of you electrically minded types see what, if any, mistake I have made? I wired it in the same way that I dismantled it from the 1275, the only difference being that the Powerspark dizzy has "2" wires whereas the Lucas jobbie had just 1. Any help would be greatly appreciated.
diz 1.jpg 69.95K
16 downloads
diz 2.jpg 59.45K
10 downloads
diz 3.jpg 73K
11 downloads
