So I bought a SC gear set last year and have only just now actually had a look at them.
Please have a look at Second, *I think* and let me know if its FUBARD!
Ryan
Edited by TehMarchant, 15 March 2016 - 10:50 PM.
Posted 15 March 2016 - 10:44 PM
Ryan
Posted 16 March 2016 - 07:28 AM
I wouldn't reuse that
Posted 16 March 2016 - 07:30 AM
fit only for the bin
Posted 16 March 2016 - 08:40 PM
Are the others like that also ?
Becareful about buying a replacement as it may not be the same gear tooth form (CP, DP or MOD) or size so will need careful checking to get it a replacement, I can help you with this if you need.
Posted 16 March 2016 - 08:46 PM
or a photo shoot .... like your avatar
Posted 17 March 2016 - 07:11 AM
Posted 17 March 2016 - 07:34 AM
yeah that was an expensive do!!!!!!!!!
make a guess which part of the mini gearbox that was!!!!
Posted 17 March 2016 - 12:19 PM
It looks like a 1st/2nd synchro hub, inner and outer the outer yeeth are too big and the wrong shape to only be the inner part.
Unless it is from a set of SC drops for an automatic.....
Edited by MRA, 17 March 2016 - 01:36 PM.
Posted 17 March 2016 - 04:28 PM
Looks like the wrong spec baulkrings were fitted in the past on that SC set
Posted 17 March 2016 - 06:34 PM
That gear in bits in my photo is what remains of a 4th/input gear/drive gear from a full race MBE dogbox. The rest of the gear were spread thoughout the engine and all over the track at oulton park.
Posted 19 March 2016 - 07:10 PM
Thanks for the help guys I forgot to follow the topic, I haven't currently this month got the money to buy replacements but I am keen to know where to look. Can I just count the ratios or is there another way to find replacements?
Posted 19 March 2016 - 10:38 PM
It's not as simple as that, if you have a gear tooth profiler then it is ...... or if you are really lucky and the gears have part numbers ot other distinguishing features.
A cheat way of doing it is to roll the gears together and then if smooth fit them in your gearbox and measure the gap between teeth on opposing gears.... but I stress this could very easily end in tears, very expensive tears
Posted 20 March 2016 - 08:27 AM
buy a brand new set it will prob be easier and cheaper in the long run
Posted 20 March 2016 - 10:46 AM
Well I am tempted to buy a new set but I spent 250 on these.
Numbers are as follow
1st 26265 29 teeth 1.93:1
2nd K75 25 teeth 1.13:1
3rd Couldn't see the number without getting the detents out. 22 teeth 0.95:1
4th 26259/2 19 teeth 0.88:1
Lay gear was hand engraved, either 21d or p18 Photo attached. 15, 19, 23 and 25 teeth
Would I also be correct saying the ratios are what is stated?
Thanks for the help.
Edited by TehMarchant, 20 March 2016 - 10:57 AM.
Posted 27 March 2016 - 03:52 PM
I know who makes your gears and should be able to get replacements for you.
Also your calcs above have only been partially finished you now have to multiply through the "compound" gear set...
4th is direct and would work without the laygear being fitted, however the teeth on the input gear (19) drives your laygear (25)
As the formula is driven / driver = 25/19 = 1.316 (we will use this later)
1st ratio between lay and 1st gear = 29/15 = 1.933
2nd ............................................... = 25/19 = 1.316
3rd................................................. = 22/23 = 0.957
Now the answer we got first comes in to play...
Driven1/driver1*driven2/driver2
1st = 1.316*1.933 = 2.54:1
2nd = 1.316*1.316 = 1.73:1
3rd = 1.316*0.957 = 1.26:1
4th = 1*1 = 1:1
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
