Posted 28 March 2016 - 04:33 PM
Posted 28 March 2016 - 04:36 PM
Leaking heater pipe?
Posted 28 March 2016 - 04:39 PM
Posted 28 March 2016 - 04:45 PM
Posted 28 March 2016 - 05:59 PM
Posted 28 March 2016 - 06:04 PM
Trace pipes through firewall .. mounting plate leaking , pipe/pipes perished .. to heater. matrix
Posted 28 March 2016 - 06:10 PM
Posted 28 March 2016 - 06:14 PM
Yep just had that problem had to replace the matrix and also had to weld two plates were the sub frame mounts are on the fire wall as the floor had split there as well all done no more wet carpet :)
Posted 28 March 2016 - 06:40 PM
Haha hope it's not needing welding not learned how to use my welder yet haha
Posted 28 March 2016 - 06:42 PM
it will leak but maybe slightly less
Posted 28 March 2016 - 07:10 PM
Posted 28 March 2016 - 07:54 PM
You will need to keep an eye on it if it is the heater as you could overheat your engine, ie same water...
Posted 28 March 2016 - 07:57 PM
antifreeze smells and tastes sickly sweet, and your radiator level may have dropped if the heater matrix is leaking.
I say may have dropped, because the leak could be causing an airlock so you may not see the level drop
Posted 28 March 2016 - 08:35 PM
Check and re-fill with coolant. Run the engine until warm and the stat is open. Check for leaks from heater pipes & heater matrix.
Repair/replace as necessary.
Posted 28 March 2016 - 09:16 PM
Or close the window
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Rear Opening & Closing Windows For A 1983 MiniStarted by Peter_NottinghamS , 05 Jul 2025 ![]() |
Occasionally Spongy Brakes (96 Spi)Started by TeddytheSpoon , 01 May 2025 ![]() |
Converting To Yellow Tag Brake Master CylinderStarted by Nickj270386 , 29 Apr 2025 ![]() |
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , 23 Apr 2025 ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
