#16
Posted 28 March 2016 - 10:32 PM
#17
Posted 28 March 2016 - 10:51 PM
i've always found that if the matrix leaks the windscreen will fog up when the fan is turned on, else it would be the hose.
#18
Posted 29 March 2016 - 07:01 AM
Have not noticed it fogging up yet but i will try that out and see what happens thanks :)
#19
Posted 29 March 2016 - 09:20 AM
On my 'S' i use steel braided hoses inside the car.
#20
Posted 29 March 2016 - 09:22 AM
The way the pipes are run inside the car is very poor design. If one of those pipes were to fail when the car was going along the hot coolant would scald the passenger's feet and the windows would immediately steam up.
Where do you get them Peter?
#21
Posted 29 March 2016 - 09:42 AM
#22
Posted 29 March 2016 - 09:43 AM
Demon Tweeks should keep it in stock.
Thanks Peter, helpful as always
#23
Posted 29 March 2016 - 10:48 AM
Imagine driving on a special stage at over 80 mph between the trees and a heater hose splits. One scalded navigator and a crashed car because of steamed up screen.
#24
Posted 29 March 2016 - 10:53 AM
For competition the regs state that any pipes carrying hot fluids through the passenger area must be either solid metal-walled tubes or steel braided flexible material and must also be marked in red. Makes sense really.
Or anywhere really.
The burns would be horrific
#25
Posted 29 March 2016 - 10:58 AM
Yeah actually now you mention it definitely will be changing to braided as i wouldn't like that to happen to me or anyone. Especially if there is a wee one in the car or my dog etc. Will demon tweeks know the required size by the car or do i ask for a specific.
Hoping to get up and have a look tomorrow see if i can source the problem. Was thinking usually for finding leaks i use a small amount of fairy liquid, will these be okay considering it can get into the cooling system? or would i be safer just doing it the normal way
#26
Posted 29 March 2016 - 11:19 AM
All you should need to do is top up the coolant and run the engine until it is up to normal working temp. Then check the pipes and inspect around the heater box for wetness.
It's a good idea to change the hoses for braided ones anyway.
Good luck with the job
#27
Posted 29 March 2016 - 01:43 PM
Id just get a box of tissues to locate any dampness.. wipe and dab keep examining the tissue for signs
#28
Posted 29 March 2016 - 03:27 PM
Ahh yeah never thought of that. Will try that method out.
#29
Posted 02 April 2016 - 07:36 PM
Lifted all the carpet and dried it all and left the carpet off to keep an eye on it.
#30
Posted 02 April 2016 - 07:42 PM
Another method to use is talcum powder. Dry everything off thoroughly then sprinkle underneath the pipes and heater.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Rear Opening & Closing Windows For A 1983 MiniStarted by Peter_NottinghamS , 05 Jul 2025 ![]() |
Occasionally Spongy Brakes (96 Spi)Started by TeddytheSpoon , 01 May 2025 ![]() |
Converting To Yellow Tag Brake Master CylinderStarted by Nickj270386 , 29 Apr 2025 ![]() |
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , 23 Apr 2025 ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
