Engine 1275 A + with stage 4 head,276 can.
Tried clutch down and no difference.At the end when switch off you can just hear a noise again.
https://youtu.be/Jkk9VisWQwc
Edited by olly33, 29 March 2016 - 09:37 PM.
Posted 29 March 2016 - 02:55 PM
Posted 29 March 2016 - 09:36 PM
Posted 29 March 2016 - 10:21 PM
Posted 29 March 2016 - 10:33 PM
Posted 30 March 2016 - 12:08 PM
Nick. Valves or drop gears?
I did the primary gear end float as this was out of spec,when i changed the clutch and oil seal.
What do you think is the issue with the valves or drop gears.?
Dusky, seems to drive ok and clutch also is ok.
I did check timing by setting piston 1 to Tdc,marks on pulley and cover line up at 0. The rotor arm was pointing slightly off from plug lead 1 on the cap,but only a fraction towards no 3 lead,which I guess is ok.
Posted 31 March 2016 - 10:14 PM
Posted 01 April 2016 - 06:58 AM
The crank shaft seal can go that quick if you didn't protect it while pushing it over the primary gear. It gets damaged very easily.
Posted 01 April 2016 - 03:49 PM
Nope I had the proper tool so know it's not been damaged that way
Posted 01 April 2016 - 03:51 PM
Could a worn primary gear cause it to leak under the seal due to clearance, as it seemed a little worn were the oil holes are on it.
I really do not know where to start looking for the knock noise at all.
Edited by olly33, 01 April 2016 - 03:52 PM.
Posted 01 April 2016 - 04:47 PM
Hi Ollie,
From your video, I can't really hear anything seriously amiss. It sounds a little tappety but that's all. You could try re-adjusting your valve clearances and see if that helps.
What rockers are you running?
Cheers, Steve.
Posted 01 April 2016 - 06:02 PM
Posted 01 April 2016 - 09:21 PM
Hi Ollie,
Cheers, Steve.
I checked them hitting the cover by all seems fine after slackening and moving it slightly while running. My dad did try the screwdriver technique but could not pinpoint it..sound same everywhere he said.Are the rockers hitting the cover? Use a very long screw driver and place it against your ear or use a stheascope to help find the exact location of the noise
Edited by olly33, 01 April 2016 - 09:24 PM.
Posted 03 April 2016 - 01:21 PM
Right I had a drive today to get it up to temp and the sound does not seem as loud once warm,but still there.
I had 60lb oil pressure on cold that then went down to 40lb when warm?
Got back and even with a new dipstick, oil has leaked from the hole again and not sure why,unless the aftermarket fitment are not the best?
Cheers again olly
Think rockers are sintered,that's about all I know about them.
Posted 03 April 2016 - 02:26 PM
Posted 03 April 2016 - 06:56 PM
78k on clock,but probably done approx 2k since Last owner had detailed pics of engine strip,and a rebuild,if this is to be believed now!
But after contacting him not so long back,he did say the pistons were not changed and think he just had a new head with bigger valves added and to run unleaded,double springs,seats etc, and probably the 276 cam.
I wonder if the oil leak from dipstick the at speed and the oil leaking again from clutch seal area is down to blowby compression in block causing the leaks?
Edited by olly33, 03 April 2016 - 06:57 PM.
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
