Zcars R1 Mini Mayfair.
62 replies to this topic
#46 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 26 September 2006 - 09:38 PM
ok let me know as soon as you are selling your kad setup !
#47 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 26 September 2006 - 09:55 PM
are these ok for a mini? i know it says mini in the title....
http://cgi.ebay.co.u...1QQcmdZViewItem
#48 Tomm
Tomm
  • 2,462 posts
Posted 26 September 2006 - 10:46 PM
Yeh they seem ok dan, i think they are the same ones that pete is using in his R1 Minus build ill just go and check.
Tomm
Look what the postie brought me today :- :dozing: :crazy:
that is the setup that petes using so them ones in the link should be alright!
#49 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 26 September 2006 - 10:50 PM
how come my postman wont bring stuff like that?
all i get is junk mail.
#50 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 27 September 2006 - 11:27 AM
Tomm
You stil need thw caliper mounting brackets, DIscs and mounting bells aswell, which is why they cost about £700 altogether from z-cars or MRA minis
#51 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 27 September 2006 - 04:21 PM
can i not use normal mini discs? or upgraded mini discs?
#52 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 27 September 2006 - 10:53 PM
inimum disc diameter is 240mm acording to spec listed, Largest mini disc is 213mm but as said you wont gain anything really by using mini discs as it is only the pad area which is a bit bigger, you need a bigger disc size to have a big improvement in brake power to make all your efforts of messing around worthwhile?
You may aswell buy a KAD set if your gonna use mini discs.
#53 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 27 September 2006 - 10:54 PM
You could put vented disks and metro four pots on the mini hubs. The rear of the z-cars kit is designed to match the track of metro vented disks and hubs so I'd use them. I have a spare set of grooved, vented disks to sell and perhaps some metro hubs with new bearings if I can find them. If interested PM me
#54 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 28 September 2006 - 04:45 PM
PM'd :-
#55 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 21 October 2006 - 08:45 AM
morning all,
what instruments are people using in their R1 cars?
i like the stack one but its damn pricey!
#56 R1minimagic
R1minimagic
  • 4,660 posts
Posted 21 October 2006 - 10:01 AM
Spa design, still cost me about £600 though!! :'(
#57 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 21 October 2006 - 10:02 AM
i chose the digi dash on mine it has every thing on it gears,revs,speedo,ot,op,wt,speed,total miles,hours run,fuel level and 0 to 60 timers the rev counter and change lights look nice but the problem i have is seeing the thing two many small screens on display at once and you have to reach across to select menus.
no good with 5 point harness. The stack looks more visable. And their all expensive.
#58 markrally
markrally
    Z Cars
  • 1,378 posts
Posted 21 October 2006 - 12:04 PM
I have fitted a stack tacho which does the RPM, speed, odometer, 1/4 mile/0-60 times etc but i havnt opted to use the addition displays as you cant see the speed etc whilst keeping an eye on oil ans water etc so i chose the racetech gauge which has oil pressure and water temp in one gauge and the pair of gauges cost under £500 as the stack only become really expensive when you need the stack sensors and addition wiring harness which cost's more than the racetech gauge alone.
Having this setup allows me to view alll the important infomation without having to press buttons on the dash and they are posistioned so they are all in view with the a quick glance.
Edited by markrally73, 21 October 2006 - 12:11 PM.
#59 Dick Dastardly
Dick Dastardly
  • 261 posts
Posted 26 October 2006 - 08:27 PM
Veypor motorcycle intelligence unit- does everything- speed, tacho, shift light, lateral g, 0-60, 1/4mile, data logger, total miles/hours, gear indicator etc, etc. Costs about £250. Can't fault it.
#60 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 26 October 2006 - 08:46 PM
n1 d!ck
do u have a link to somewhere that sells these? (exept the zcars site lol)
not that they are too expensive ... :/
