Hi again, few problems with my dashboard clocks ect. Indicator light on the left hand side doesn't work I've looked at the bulb and tested for resistance and no resistance showed so it was fine even though it isn't that much of a problem it nice to know whether you've been indicating left for the past half an hour or not
Another problem is the back lights only one turns on (rev counter) when the lights are on so the dark is an issue as I can't see how fast I am going 😑. I did have a problem with the alternator light until one day it decided to turn itself on so touch wood it stays on 😬. And last but not least the speedo is 5 mph out at true 30mph so to do 30 it has to show 35mph and then from there the numbers are anyone's guess as once I hit 40 the true speed is 32mph?
Could anyone please help been struggling for a while now I have tried cleaning all the connections, checked a fuse box as I can't find the rest even going off the Haynes manual and I've checked all the wires and bulbs for breaks. Nothing has worked help would be greatly appreciated
Thanks Lewis
Dashboard Lights And Speedo Catastrophe
Mini30owner1989
, Apr 27 2016 09:55 PM
electrical
5 replies to this topic
Posted 27 April 2016 - 09:55 PM
Posted 27 April 2016 - 11:15 PM
Does anyone know whether or not the circuit board at the back of the dials is connected in series or parallel as that may be my problem :/
Posted 28 April 2016 - 01:59 AM
The printed circuit is a possibility, especially if it's got wet. All the illumination bulbs are in parallel. The earth is a common factor for the indicator and illum.
Posted 28 April 2016 - 04:48 AM
Inspect the circuit too, ive seen them break. Quite easily restored with conducrive glue.
Posted 28 April 2016 - 07:14 AM
Ok thanks a lot I'll have a look and see what I can do
Edited by Mini30owner1989, 28 April 2016 - 07:16 AM.
Posted 07 June 2016 - 04:05 PM
Fixed it just needed to clean up all the connections on the circuit board
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
1987 Mini Rover Fuel Gauge IssueStarted by kwfranky , 11 Jun 2025 ![]() |
