Erics New Engine - Supercharged 1293Cc
#76
Posted 09 April 2017 - 07:31 PM
#77
Posted 09 April 2017 - 08:32 PM
Very nice......nuff said... ![]()
Edited by andrewmini67, 09 April 2017 - 08:35 PM.
#78
Posted 20 May 2017 - 05:11 PM
Finally got some garage time this weekend :) so.......
Manifold & Charger fitted.
Fuel Filter filter fitted.
And a few auxiliaries back on.
Posted 20 May 2017 - 05:19 PM
I've also manage to fit the new fuel pump and have started to look at how to route charger belts and check for clearances (fan blades & fan belt).
Posted 20 May 2017 - 05:22 PM
It doesn't look as through ill have much bonnet clearance, but I'm sure it'll go on.
Posted 21 May 2017 - 06:49 AM
Very nice!
#82
Posted 23 May 2017 - 09:30 PM
Looks great Oliver. Did you buy an LCB manifold and have you decided on the cooling system yet? That bonnet clearance looks too close for comfort, hope its not going to be a problem for you. I have a "scrap" bonnet you can play with if you need to make some cosmetic changes.
Edited by andrewmini67, 23 May 2017 - 09:33 PM.
#83
Posted 23 May 2017 - 11:09 PM
Anyone know if they make a version that accommodates LHD?
#84
Posted 23 May 2017 - 11:18 PM
According to the website:
The dcoe supercharger kit can be used with all bodyshells 1959-2001- no bonnet or bulkhead modifications required, left and right hand drive, with the pedal box servo assembly, kits are tailored for Small to large bore engines.
https://www.vmaxscar...percharger-kit/
#85
Posted 23 May 2017 - 11:21 PM
Thanks Timmy850. In post #79, the second picture looks like the drive completely fouls the master cylinder locations for LHD. I guess they must have a different drive arrangement for LHD.
#86
Posted 10 June 2017 - 07:54 PM
Cheers Andrew, I'm keen to get things going so at the moment I'm pressing on with the manifold I have. I think it will be close but the bonnet should go on.... I'm loving the look of the engine at the moment so I may even mad max it and not fit a bonnet..... I wish.
Cheers for the offer.
Edited by Torgo, 10 June 2017 - 07:54 PM.
#87
Posted 10 June 2017 - 07:56 PM
I see what you mean... I would drop Vmax an email I'm sure Stuart will confirm how it all works for a LHD.
#88
Posted 10 June 2017 - 08:04 PM
WOOOOOOOOOOOOOP WOOOOOOOOOOOOOOOOOOOP
Big steps taken this weekend, for the first time in a year Eric rolls out of the garage and has an engine ready to start :)
After a lot of checking and double checking I gave it a go............. and it ran :)
I only ran it for a few seconds at first but it ran :)
Posted 10 June 2017 - 08:19 PM
Here's a vid of the first start up:https://youtu.be/7SevOMw1KwA
Ignore the water leak coming from the water temp sender ....... ooops.
#90
Posted 10 June 2017 - 08:25 PM
My next job is to get the Cam bedded in........
I seem to only be able to get it to start by using a lot of choke at the moment but will look at this tomorrow, I'm thinking that's as I've fitted a facet fuel pump and not adjusted the regulator since it came out the box I may be over pressure on fuel?
To keep it running I have to give it some choke and revs as soon as I release the choke it dies......
