Mini 93 Scratch Build...
roundnose
28 replies to this topic
#1 Joshfman
Joshfman
  • 33 posts
Posted 21 May 2016 - 06:13 PM
Hi guys
I ve been reluctant to post on here as Ive had negative comments before on other sites and it puts a downer on things (hopefully that wont be the case here). I bought a mini for my second car a long time ago and had to put it in the garage after a certain time of driving it to change the clutch. Anyway, when I pulled the engine out and dug around I found a load of corrosion, the more I dug the more I found. eventually the car ended as a bare shell with lots of problems. My father decided it was best to pull the car completely to pieces and rebuild it from scratch. At the time I wasnt really savy with minis or rebuilding cars and agreed. Since 2012 I have had a car that has been in pieces literally..... Only now the real worked has happened, So I've decided to share it with you guys. I am sure not alot of you have seen this kind of idiocracy been carried out and thought I would post it for your amusement and also your help!!
#2 Joshfman
Joshfman
  • 33 posts
Posted 21 May 2016 - 06:26 PM
Here are the most recent photos http://s53.photobuck.../?sort=3&page=1. I do have loads more photos of progress previous to this but they are on my old phone and cant be taken off. obviously there will be more to come
#3 Joshfman
Joshfman
  • 33 posts
Posted 21 May 2016 - 06:32 PM
I made up the jig to keep the subframes in a fixed and aligned position. the heights are set according to a dimension sheet and are all mesured from a datum wich is the two main longitudinal
beams of the jig. I got this idea from a user on here called Tom Sanderson.
#4 JCP
JCP
  • 74 posts
Posted 21 May 2016 - 06:39 PM
Wow, you really meant its in pieces! That's a big project you've got there,
keep the pics and updates coming when you can, will be good to see its progress as you go along, and eventually the finished mini.
#5 Joshfman
Joshfman
  • 33 posts
Posted 21 May 2016 - 07:07 PM
20160521_181607_zpsbxou6nh0.jpg20160521_181525_zpsocv0yrqj.jpg20160521_181348_zpsmvxwumcb.jpg20160521_140247_zps4fphzfph.jpg20160515_163201_zpssabtjkgi.jpg20160515_163151_zpsjswmrbdn.jpgIMAG0004_zpsbibchznl.jpg
#6 pdaykin
pdaykin
  • 587 posts
Posted 21 May 2016 - 07:09 PM
If I had a hat I would be taking it off to you.
Impressive stuff
#7 Joshfman
Joshfman
  • 33 posts
Yeah totally in pieces...its the biggest mistake ever. Should be fun. If you have any tips or help ill be glad to listen in! cheers
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 21 May 2016 - 07:14 PM
Wow, you're not messing about.
Good luck and keep up the good work.
#9 Joshfman
Joshfman
  • 33 posts
Posted 21 May 2016 - 07:23 PM
Sadly not. Its been hell so far. Biggest problem of all was the fact had no references. If you have any tips or hints they would be much appreciated. Cheers.
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 21 May 2016 - 07:25 PM
Actually mate, I've seen some references somewhere.
Be right back
#11 JCP
JCP
  • 74 posts
Posted 21 May 2016 - 07:28 PM
My biggest tip is have patience, and lots of it, if something isn't lining up/screwing in or what ever, walk away and leave it for a while, better to come back a few hours later or the next day than break or cross thread something and cause a lot more work and frustration.
Also don't be afraid to ask questions on here or other sites, no matter how stupid you think it may be, although do have a search to see if it's already been asked, there's a wealth of knowledge on here and lots of resto projects going on, chances are someone will have had a similar problem at some point.
#12 Carlos W
Carlos W
  • 10,114 posts
http://www.theminifo...ig-information/
this isn't the one I was looking for, but it'll probably do for now.
I'll keep searching
#13 Carlos W
Carlos W
  • 10,114 posts
Posted 21 May 2016 - 07:36 PM
#14 Joshfman
Joshfman
  • 33 posts
Posted 21 May 2016 - 08:04 PM
Thanks JCP. A cup of tea normally sorts head melting moments ha!
#15 Joshfman
Joshfman
  • 33 posts
I'll keep searching
Nice one Carlos that jig picture will be a massive help. I wish i had found it before making mine!!!
