Only One High Beam Working
electrical
2 replies to this topic
#1 Kia890
Kia890
    Starting My Mini Up
  • 1 posts
Posted 05 November 2016 - 08:32 PM
Hi,
New to the forum but have used it to solve many a problem before.
I have a 1987 Mini Mayfair 998cc and have owned it for the last few years, having got it back to a daily driver for now. However, within the last week my drivers side main beam doesn't want to work at all.
I have replaced the whole lighting loom from the bullet connectors to the light on both sides, changed to brand new bulbs and still nothing.
 A check across the terminals on the light tells me that I am getting a voltage there but no lights at all. I have 4 bulbs which I have tried and none of them work, although they do on the passenger side light.
All fuses are correct and I have traced all wires for breakages, which obviously isn't the problem due to a voltage being present.
Has anyone ever had a similar problem because this has confused me to the point of insanity.
Thanks,
Kia890
#2 Cooperman
  • 23,332 posts
Posted 05 November 2016 - 09:22 PM
If you have 12 volts to the bulb terminal(s), the bulb is OK and the bulb is earthed it will light up.
So now, using a multi-meter, trace the power, check the bulb (both main-beam & dip), and check that it earths.
#3 sledgehammer
sledgehammer
  • 3,109 posts
Posted 05 November 2016 - 10:10 PM
I would check the bullet connectors behind the front panel again - they are a real pain when they get corroded
sounds like you are getting volts , but no amps , so there is resistance in the circuit
I would make a new known good earth , & try that - if no luck , the problem is resistance in the bulb +ve to the bullet connector
the above is a guess - as I haven't worked on the car
on my own car , I have made up an earthing bolt on the inner wings , both sides , instead of the -ve joining at the bullet connector
the +ve's are 4 separate wires going to dedicated relays , so no joins behind the front panel
Edited by sledgehammer, 05 November 2016 - 10:17 PM.
