Lucas 6Fj Fuseboxes Modern Fuses
electrical
4 replies to this topic
#1 CheckNL
CheckNL
    Starting My Mini Up
  • 3 posts
Posted 15 May 2017 - 09:44 AM
Hi all,
Have a question I cannot seem to find the answer to so thought I'd try it in here.
The thing is I'm building a Works mini replica and have a question about the fuseboxes I want to use.
In the original Works cars they use the Lucas 6FJ fuseboxes (http://www.ebay.com/...Y-/231979401602).
Since I don't feel like using glass fuses I would like to know if someone here nows if there's a solution to use the 6FJ boxes with modern fuses.
Could be someone has made it themselves or someone knows a company that makes these old boxes with mods to accept new fuses.
All ideas are welcome.
#2 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 15 May 2017 - 09:50 AM
Just use a blade type fuse box, piggy back spade connections to join wires
#3 whistler
whistler
  • 1,831 posts
Posted 15 May 2017 - 11:23 AM
If you're making a Works Replica then you should use what they used otherwise it's not a replica.
#4 Spider
  • 15,201 posts
Posted 15 May 2017 - 11:32 AM
I've used these in place of the original;-
http://www.carbuilde...-box-side-entry
They have a number of different types and fuse capacities. Something else may suit your needs better.
You can also get circuit breakers that go in place of the fuses that have built in LEDs to show one that's tripped. Very handy on a stage car at night.
#5 nicklouse
  • 18,724 posts
Posted 15 May 2017 - 11:42 AM
I have one of these. when a fuse blows it shows you which one has gone.
http://www.12voltpla...leds-6-way.html
available with more or less fuses.
