Mini Mayfair restoration
#16
Posted 26 November 2006 - 10:21 PM
#17
Posted 26 November 2006 - 11:31 PM
get some pics up
#18
Posted 27 November 2006 - 12:34 PM
what is the interior looking like?
get some pics up
havent got any interior in the car at the mo but ill put some pics up later that i have at home!
#19
Posted 27 November 2006 - 11:20 PM
DSC01538.JPG 151.39K
37 downloads
Edited by minimad998, 27 November 2006 - 11:20 PM.
#20
Posted 28 November 2006 - 11:29 AM
shagadelic
#21
Posted 28 November 2006 - 04:01 PM
#22
Posted 28 November 2006 - 11:42 PM
#23
Posted 29 November 2006 - 03:26 PM
#24
Posted 29 November 2006 - 05:19 PM
good luck with the mini project
looks like you have your work cut out for you!
thanks for the luck Wendy hopping on having the car in for the mot some time near x mas
i think i shall hav to sort out the fact that the electrics from the battery run under the driver seat and through the air vent into the engine first, b4 i can worry about sound systems. but good on u ... u lucky sod. lol are u doin the welding ur self?
ive got a mate giving me a hand with the welding, actually hes done pritty much all the welding if im honest
#25
Posted 07 December 2006 - 11:06 AM
When i removed the head i found out that the block did need pocketing as the blue tac had been completely flattened, maybe 5mm is too much but i would rather take a little too much out (not too much so that the top ring is in the pocket of course) and not bend a valve then bend one, if worse comes to worse ill have to have the head skimmed to increase the compression ratio again, but we will have to see i started to pocket the block yesterday, ive managed to complete one pocket on no 1 cylinder using a rotary bit for milling out the material and then a sand stone to buff up the cast iron once the material had been removed, I used the gasket as a rough guide and then left 1mm between the gasket and the pocket, I have made the pocket 5mm deep. everything is looking good so far ill post some pics later on!!
#26
Posted 07 December 2006 - 10:09 PM
using_gasket_as_a_guide.JPG 142.02K
51 downloadsi used the gasket as a guide
engine_covered_for_pockting.JPG 137.56K
47 downloadscovered the engine up so that no metal fragments went down into the bore of the engine
nadonium_magnet.JPG 142.63K
32 downloadsthe us of nadonium magnets to remove any random fragments from the bore
finished_job.JPG 133.83K
31 downloadsand the finished block all pocketed this roughly took me about 5 hrs to complete!!
let me now what you think!!
Edited by minimad998, 07 December 2006 - 10:11 PM.
#27
Posted 08 December 2006 - 04:22 PM
#28
Posted 08 December 2006 - 07:58 PM
#29
Posted 11 December 2006 - 08:45 PM
engine.JPG 258.92K
23 downloads
clutch.JPG 271.81K
18 downloads
#30
Posted 12 December 2006 - 10:45 PM
presure_plate.JPG 296.68K
15 downloadsRyan
