No replies to this topic
Posted 22 July 2017 - 02:30 PM
Are the rod bolt sleeve that connects from m rod linkage to gearbox suppose to be a loose or snug fit. You can see mine rattles about in the rod Change rod (pins removed) Is this normal play?
IMG_2284.JPG 26.48K
8 downloads
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
