No replies to this topic
Posted 22 July 2017 - 02:30 PM
Are the rod bolt sleeve that connects from m rod linkage to gearbox suppose to be a loose or snug fit. You can see mine rattles about in the rod Change rod (pins removed) Is this normal play?
IMG_2284.JPG 26.48K
8 downloads
