1973 Mkiii Restoration
#46
Posted 26 September 2017 - 09:28 PM
#47
Posted 26 September 2017 - 09:46 PM
I love MK 3's.
Later minis went "soft" in my opinion. Rubber mounted front subframes and all that....
Look forwards to the updates and I know what you mean about storing stuff. It's hassle.
Wait till you try to find things later
#48
Posted 26 September 2017 - 10:05 PM
I love MK 3's.
Absolutely. My concern is getting everything back together right getting the right number and right size fixings in the right places.
Learning loads though.
Have to say your thread should point me in the right direction. Staggering attention to detail. I won't be upgrading much on mine the intention is to keep the car as is, minus rust. It will never compare with my daily drive regardless of what I do to it performance wise but will put a smile on my face if I do a good job.
#49
Posted 26 September 2017 - 10:38 PM
Needed space to store stuff I don't want near the grinder and welder so spent this evening rearranging the garage and sheds so I can empty all the trim and chrome and plastic and glass out of the garage during the strip. As a result have done nothing to the car. Still waiting on this socket set too.
Cleaning is part of the restoration in my book.. it's also a time saver as I've spent lots of time looking for tools or moving things about.. Agreed. Petrol's restoration is the best that I've found..
#50
Posted 29 September 2017 - 04:04 PM
I've subscribed to your thread, because I am really interested in watching this build. So far it looks like you are cranking along. Great work!
#51
Posted 29 September 2017 - 04:49 PM
Hoping to finish stripping seat belts, ash tray, companion bins, gear change, seat mounts, nasty 80's ICE, rear lights, glass, doors brakes, then jack the car to attack the engine removal. Written down there is still loads to do on the strip down.
Constantly feel like I've bitten off more than I can chew.......just got to swallow it I guess and keep plugging away.
#52
Posted 29 September 2017 - 05:23 PM
Sounds like a fun project! As for the "bitten off more than I can chew" comment, I know what you mean. Keep at it, and keep on posting pictures. I love seeing progress.
#53
Posted 29 September 2017 - 09:25 PM
Seriously how do you get a elfin huge dent here? With rust? I have no idea.
#54
Posted 29 September 2017 - 09:29 PM
My bulkhead was dented and that was from the spare wheel hitting it when it had a tail end shunt.
#55
Posted 29 September 2017 - 09:33 PM
but this is behind the fuel tank?
I'm wondering if it was shunted (from inside the car) backward then overcorrected forward then bent back so you have a bulge and crease going downward toward the seat. It is bizarre. The centre of the panel is straight and smooth.
Edited by 73MkIII, 29 September 2017 - 09:34 PM.
#56
Posted 30 September 2017 - 07:33 AM
Is the fuel tank out??
#57
Posted 30 September 2017 - 07:41 AM
#58
Posted 30 September 2017 - 09:28 AM
Have you checked if there is evidence of 1/4 panel and wheel housing
repair or replacement looking at that damage I would recon the car has
had some side impact at sometime !
I like your Mini by the way good base for a project if possible I would do
your best to keep the original features on the floor grommet holes FE plate
in the O/S footwell ect best of luck.
#59
Posted 30 September 2017 - 09:53 AM
Sorry. I am being slow but what do you mean by FE plateHave you checked if there is evidence of 1/4 panel and wheel housing
Yup slow. Found it now
Edited by 73MkIII, 30 September 2017 - 09:56 AM.
#60
Posted 30 September 2017 - 09:54 PM
Busy evening this evening. Seat brackets, handbrake assembly, Cruddy ICE, door cards, rear cards, Seat belts, Windscreen and rear screen all out. Doors are very good just some rust creating into the bottom seam so will need to do something with those, but for 44 years old I was very surprised by the state of the doors.
last few photos are down the inside of the door towards the bottom seam.
Cards are still in very good condition so hope will just clean up.
Headlining and vinyl trim need removing, the bits of carpet round the door step, rear side windows, Then rear lights and rear bumper to remove then on to the undercarriage and engine removal.
looking now I suspect the bulkhead is spare wheel or boot damage that has been badly repaired just to get the seat back to fit flush.
Onwards and upwards.
