Indicator & Speedometer Problem
electrical
2 replies to this topic
#1 1987 Austin Mini Advantage
    Starting My Mini Up
  • 1 posts
Posted 09 December 2017 - 08:04 PM
I have a 1987 Austin Mini Advantage I recently bought, when I got it the speedometer, hazards, horn & indicators were not working. I changed the relays and got hazards and horn working. Ive also got the right hand side indicators working the only issue I have now is still the speedo and the right hand side indicators.
Has anyone got any ideas on how to fix this?
#2 cal844
cal844
  • 9,660 posts
  • Local Club: TFMOC
Posted 09 December 2017 - 10:00 PM
What is the issue with the Speedo?
As for the indicators change the inline fuse (purple/orange wired inline fuse at the carb) then the switch and relays also check the earth's on all 4 light units. Then check and clean the wiring connections behind the fusebox
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 December 2017 - 12:46 AM
Also check the bullet connectors behind the grill know for bad connections, check the FAQs electrical for the colours
