What Needle To Use For My Hs4 Carb?
engine
3 replies to this topic
#1 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 23 January 2018 - 07:46 AM
Hi all,
Been having problems lately with my engine. would just die while idling, very sluggish, erratic with the throttle open etc.
Decided I'd just go for a full Carb rebuild to see if that sorts it out.
Am running a 998 series A from 1976, completely unmodified.  Carb is a waxstat type HS4.
Needle doesnt look like it needs replacing, but suppose i wanted to anyway, what would be a good needle to go for? I'd like to go for a stage 1 upgrade sometime in the not too distance future, so should I get a needle geared towards that? Or will my performance suffer until a stage 1 kit is installed?
Worth pointing out that this car is for casual road use, not any kind of racing or performance oriented use.
#2 carbon
carbon
  • 2,590 posts
Posted 26 January 2018 - 08:38 PM
For a standard engine you should fit the standard needle.
When you have it off for rebuild check the throttle spindle and bushes for wear, this could cause erratic idle.
#3 cal844
cal844
  • 9,637 posts
  • Local Club: TFMOC
Posted 29 January 2018 - 10:43 AM
Only change the needle when you upgrade to stage one.
#4 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 31 January 2018 - 10:17 AM
Thanks for the reply guys! How would I know what the right needle to get for my car would be? There are just so many options out there.
As far as I can tell the current needle is in good condition.
