Thanks. This helps...i checked inside the chamber and can see the one O ring is still in there.
The kit came with 2 big and 2 small O rings.
What came out looked like 1 big and 1 small and that's what I did when I replaced it but the small somehow seems to have come off.
So to confirm it's just the two O rings and the spacer on the end?
I just rechecked the bits that came out of mine and they look like the same size, two small o rings, with the spacer at the end. I wonder if yours had the wrong size at the spring end?
The diagram above for the newer type of piston is confusing because it shows two small o rings at the end, but one of those is the "installation position" and the other shows the same ring in the "operating position" The o ring next to the spring should also be a small o ring.
At least that's how I read it based on what came out of my old cylinder and the statement that "the smaller pair of O rings are fitted to the new piston assembly"
Edited by Lplus, 23 June 2024 - 07:32 PM.
