Electrical Issue - Switch On Headlights And Fuel Goes Up Past Max...
electrical
7 replies to this topic
#1 jezjsa
jezjsa
  • 90 posts
Posted 12 May 2018 - 02:05 PM
Hi.
If anyone has any idea, that would be great....
So, put a new dash in this morning, and i don't know whether I've knocked something or what but now when I switch on sidelights or main beam, the following happens! (its a three-dial dash in front of the steering wheel if that helps).
1. Fuel gauge goes well past full, even though its actually only half full.
2. The indicator lights in the dash both light up - though the actual car lights on the car don't.
3. Full beam dash light doesn't light up when used, again the actual full beam does work.
4. Rev counter needle slightly goes up!
So it's like the centre gauge of the three has got issues, even though before it was absolutely fine.
#2 CityEPete
CityEPete
  • 3,920 posts
Posted 12 May 2018 - 03:38 PM
It's been a while since I've messed with a binnacle but it sounds like you've forgotten to run a good earth wire to the binnacle to me, the various circuits then go bananas!
#3 andyapanel
andyapanel
  • 626 posts
Posted 12 May 2018 - 04:18 PM
I agree; I think there is a bad earth, so the current is running thru the other circuits.
Check the printed circuit.
Good luck.
#4 jezjsa
jezjsa
  • 90 posts
Posted 12 May 2018 - 07:30 PM
thanks for the pointers... ill see how i get on tomorrow :)
#5 Cabriomin
Cabriomin
  • 44 posts
Posted 13 May 2018 - 10:48 PM
Corroded or damaged printed circuit board?
#6 pusb
pusb
  • 1,216 posts
Posted 14 May 2018 - 05:29 AM
I had a similar problem before. With the headlights on, the temp gauge would always shoot up.
Turned out the earth wire from the binnacle had detached
#7 jezjsa
jezjsa
  • 90 posts
Posted 15 May 2018 - 09:49 PM
Ok so wiggled the wires under the steering column and all is back to normal... not just got to figure out which wire is faulty. Ah.... the joys of the classic mini :)
#8 CityEPete
CityEPete
  • 3,920 posts
Posted 16 May 2018 - 04:32 PM
Certainly sounds like the binnacle earth to me then.
