Headlight Issue
electrical
9 replies to this topic
#1 Ol timer
Ol timer
  • 329 posts
Posted 19 May 2018 - 03:59 PM
I seem to having an issue with the headlights on my 1972 Mini 1000
it originally started with the Drivers side headlight not working..
The bulb is ok, and I checked out the bullet connections under the grille and found a few of the double female connectors to be  corroded.
I have  since replaced them but I am having the same problem, I changed the loom to a newby and still no Joy.
the parkers don't work either, however if I switch to High beam both high  beams work
So what I have is no parkers both sides, headlight only passenger side.
I have buzzed out the connections, including the earths with a Meter and everything seems to be ok.
I am now totally lost and have given up. has anyone got any tips re this issue , and or know of a Mini  friendly electrical centres in the west London area..
Thanks in advance
Kevin
#2 nicklouse
  • 18,624 posts
Posted 19 May 2018 - 05:21 PM
i see no mention of actually checking for 12V any where. work you way back till you find the 12V.
#3 Ol timer
Ol timer
  • 329 posts
Posted 19 May 2018 - 06:14 PM
I will double check the 12v outputs again behind the grill, but if I am getting high beam to work on all, then that eliminates the green and white wire behind the grill as the fault and the same for the Green and red If I am getting normal beam on the passenger side. would I be right in saying that both headlights share the same 12 Volts?  it just seems confusing as the volts are there
I have just noticed that the tail lights are not working either
Edited by Ol timer, 19 May 2018 - 06:48 PM.
#4 gazza82
gazza82
  • 3,016 posts
  • Local Club: TMF+
Posted 19 May 2018 - 08:25 PM
High beam are blue/white, dip blue/red and sides red. Not sure what your green/white is?
#5 cal844
cal844
  • 9,626 posts
  • Local Club: TFMOC
Posted 20 May 2018 - 07:47 AM
Fuse, or the headlight stalk
#6 Ol timer
Ol timer
  • 329 posts
Posted 20 May 2018 - 08:42 AM
My bad, dont know my blues from my greens.
#7 A-Cell
A-Cell
  • 1,610 posts
Posted 20 May 2018 - 11:13 AM
Headlight dip blue/red tracer
Headlight main blue/white tracer
Sidelights red
Indicator right green/white tracer
Indicator left green/red tracer
#8 CityEPete
CityEPete
  • 3,920 posts
Posted 20 May 2018 - 12:26 PM
Head light switch is a favourite, bottom fuse holder/wires/terminals corroded could be the issue with the parking lights, do the binnacle lights work?
#9 Ol timer
Ol timer
  • 329 posts
Posted 20 May 2018 - 09:32 PM
just checked, binnacle lights not working
#10 Ol timer
Ol timer
  • 329 posts
Posted 22 May 2018 - 05:58 PM
Good News.  managed to resolve the issue
I replaced the Light Switch, the Terminal connectors on the Fuse box and the headlights started to work
however I still didn't have rear lights, Parkers and Binnacle lights.
Looking through other posts online I found an inline fuse near the washer bottle that was also blown, replaced and now everything works.
One thing I also did was replace the Halogen Headlight bulbs for less power drawing bulbs in case that was the problem.
Thanks everyone for your assistance...
