Electrical Faults
electrical
10 replies to this topic
#1 Benga24
Benga24
    Starting My Mini Up
  • 3 posts
Posted 13 June 2018 - 07:14 AM
Hello there,
Complete mini newbie here, just picked up my 1989 Austin Mini Mayfair (picture attached), drives great but the electrics do not seem to function properly. The brake lights, horn, wipers do not work, the indicators are intermittent but the hazards work fine, and the headlights do not work other than flashing the high beam. I suspect with the amount not working that it's likely a fuse but I could do with some pointers on how to replace these?
The car was put through its MOT, with no advisories, by the previous owner only 2 weeks ago, so I doubt it is anything serious.
Also, apologies if this is a common post, like I said I'm new around here :)
#2 JXC Mini GT
JXC Mini GT
  • 856 posts
Posted 13 June 2018 - 09:33 AM
A lot of the electrical problems are due to poor earth connections and poor connections to the fuse box, I would look at the fusebox first and check fuses then check and clean all connections to the fuse box.
#3 cal844
cal844
  • 9,667 posts
  • Local Club: TFMOC
Posted 13 June 2018 - 09:38 AM
Clean the fusebox and wiring connections, then clean the wiring connections behind the grille and also the main loom earths at the drivers side next to the screenwash bottle
#4 kyle_1275
kyle_1275
  • 37 posts
Posted 13 June 2018 - 09:50 AM
I suspect you know where your fuse box is? Just in case you’re unsure it’s located to the left side of the bulkhead slightly to the left of where the carb sits. Unless it has been moved by the previous owner.
#5 CityEPete
CityEPete
  • 3,920 posts
Posted 13 June 2018 - 10:36 AM
Clean all the connections on the starter solenoid as that's where they originate from after the main battery cable, clean the battery terminals and the earth strap to boot floor.
#6 ukcooper
ukcooper
  • 1,625 posts
Posted 13 June 2018 - 10:52 AM
well to the world off minis ha ha, start to learn fast start with the wiring behind the grill and get yourself a test light
https://www.ebay.co....H8AAOSwugha1PXS
easy to use and invaluable in fact I get 2 crocodile clip to earth then point to live it lights up no live feed it don't light up
#7 Mike L
Mike L
  • 159 posts
Posted 13 June 2018 - 11:30 AM
You can find wire diagrams that should help you trace things down here:
http://www.theminifo...agrams-redrawn/
#8 Benga24
Benga24
    Starting My Mini Up
  • 3 posts
Posted 13 June 2018 - 11:36 AM
Thanks for the tips, I'll have a poke around with the tester tonight and clean the fuse box up. The dials aren't working either, apart from the fuel and coolant lights, would that be likely the same problem?
#9 Benga24
Benga24
    Starting My Mini Up
  • 3 posts
Posted 14 June 2018 - 05:47 AM
Update: managed to get everything working apart from the gauges. It’s a 3 clock dash, the lighting works but none of the needles move. Any ideas?
#10 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 22 June 2018 - 12:04 PM
3 clock has a printed circuit board I think .. it's often bad tracks on that ..
#11 Mike L
Mike L
  • 159 posts
Posted 22 June 2018 - 01:29 PM
If it turns out to be the printed circuit board they are available new from Mini Spares. There may be a couple types so make sure you get the one that matches yours.
