I see a lot of these on my local auction site - the little kit runs about 27 000 JPY anyone tried one ?
Here's a youtube vid showing the difference in spark boost - pretty impresive
and installed in a mini
Posted 22 October 2018 - 12:36 PM
Posted 22 October 2018 - 11:14 PM
Having had an NGK plug melt with electronic ignition toe down on a lean mixture I would question how well it would be on plugs
Certainly looks like lightening
The in car video is pointless to us in the UK....I know a few words of Japanese which does not help
...nebari uro suiban suiseki and kanichiwa non any use for cars hahah... even bonsai size
Any tests or figures to back any claims ?
Posted 22 October 2018 - 11:23 PM
never had any spark issues without anything like that. why add something else that may go wrong cause issues.
Posted 23 October 2018 - 12:23 AM
I did a little looking around and looks like these have been around a while already,
the in car vid - I think the guy drives up the hill at 2000 rpm and then checks his time then he does it again with the booster deconnected, not very scientific but he was faster with the booster ! It was just to show that some people have got it fitted
I have seen home made ones and people are claimng better mpg and smoother running - if some cash came my way (which looks unlikely) I would be ready to try one out. The same guy who makes the booster also makes a Plasma coil for the mini - the name alone sounds fast imo !
Nice bit of reading here
http://www.aquapulse...nition/faq.html
and our man himself
Edited by ryomini, 23 October 2018 - 02:31 AM.
Posted 23 October 2018 - 05:01 AM
This works on a very simple principal of L-C Resonance.
It will really punch up the volts, no risk there, but in doing so, you can be almost guaranteed HT Lead, Distributor Cap and Rotor Button issues.
You can read up on L-C Resonance here;-
https://en.wikipedia...wiki/LC_circuit
Posted 23 October 2018 - 10:18 AM
Interesting but too high tech for my brain and abusing the HT system is not worth it for a small and dubious gain.
A set of S points and a high quality condensor will do.
Posted 23 October 2018 - 08:46 PM
I have done quite a bit of research in sparkplugs etc.
These do work, to an extent. But erode plugs and other components so fast that it gets useless, although another proof that we can gain power/torque and driveability by providing a better way of igniting our mixture.
I have some test results somwhere, I should put everything on a site one day to share it with everyone. Brisk multisparks are still my favorite plug for those of you who haven't seen me repeating this for the 10th time..
Posted 23 October 2018 - 10:26 PM
some interesting reading
Brisk isn't a multiple ground plug though.
Posted 23 October 2018 - 10:59 PM
never said it was.
Posted 24 October 2018 - 06:07 AM
Keeping obstacles to flame development to a minimum is one of the performance factors, as mentioned
@dusky, so would you try the brisk plug WITH the plasma booster ?
Posted 25 October 2018 - 09:45 PM
I would not. It would eat those plugs alive, and at +- 10£ a pop it costs quite a bit.
Mind, it would give very intresting results. I'm still trying to get some free samples of them to broaden my research.. :)
Posted 26 October 2018 - 08:14 AM
you only need enough to light the mixture properly, so unless your running alcohol or somthing then theres not a lot of point.
Posted 26 October 2018 - 04:47 PM
Not really true.
Imagine a room full of kindle. What would burn it the fastest? Light it with 1 match, 1 blow torch, or 3 blow torches close to eachother?
Posted 26 October 2018 - 07:20 PM
Mini Technical Sections →
Problems, Questions and Technical →
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , Today, 01:59 AM ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
