Gearbox Rebuild - Bell Crank Pivot
engine
3 replies to this topic
#1 Projectmini_kwt
Projectmini_kwt
  • 15 posts
Posted 07 December 2018 - 11:26 AM
Hello there
Busy with a rebuild of a gearbox and one the boxes i am rebuilding has a leak from the bell crank pivot pin. So i want to teplace the o ring but i have never removed the pin before and it seems to be pressed in. Any suggestions or experience on how to push this part out so i can clean replace and re install!!
#2 big john
big john
  • 31 posts
Posted 07 December 2018 - 12:50 PM
I usually screw the nut back on to protect the threads and use a block of wood and large hammer to tap it down and out. The gearbox gasket sets typically don't come with the o-ring you will find around the bottom part so I reuse the one that comes out and give it a good smear of RTV. The fit is so tight that they rarely leak after that. Check and make sure the case isn't cracked in that area though.
#3 Spider
  • 15,079 posts
Posted 07 December 2018 - 05:33 PM
I press them out to keep them nice and square and likewise to refit as they need to be tight in the case - that's all that keeps them there, though I've never tried tapping them out as big john has suggested.
I also well support the case around them when pressing them as that first 'crack' can take a bit of force, most of these have been there a long while! I fit a deep socket over the Pin and land it in the base of the Pin to press them.
As big john also mentioned, the O Rings aren't supplied in the kits but are available as a separate part.
I fit them back with some Loctite, not just to help hold them but also to help with the sealing of them.
#4 Projectmini_kwt
Projectmini_kwt
  • 15 posts
Posted 07 December 2018 - 06:09 PM
Hi both
Thanks very much for your advice and experience! Its much appriciated !!!
And will let everyone knows how it goes
