Edited by stumpy75, 08 May 2019 - 05:13 PM.
Budget Rebuild
#76
Posted 07 May 2019 - 04:51 PM
#77
Posted 08 May 2019 - 09:28 AM
Thanks mate if anyone has a genuine step they would be willing to take the measurements off in order to make them accurately that would be great mine have been potched with in the past
I have a genuine BL step panel if you are still looking for measurements
#78
Posted 08 May 2019 - 03:09 PM
#79
Posted 08 May 2019 - 03:11 PM
#80
Posted 08 May 2019 - 04:22 PM
Edited by stumpy75, 08 May 2019 - 04:26 PM.
#81
Posted 08 May 2019 - 07:50 PM
Thank you very much ime making it up as i go read a bit then have a go
Well your doing a great job and im enjoying the build almost as much as you must be
#82
Posted 08 May 2019 - 07:51 PM
So all thats silver isnt good steel is not from the outside it looked clean steel when i drilled a few holes i had little clouds of rust from the drill bit
Also the a pillar (wich i rebuilt previously) from the top of the door check bracket up to the roof as far as i could see with an endescope were full of surface rust inside only 1 option get it cut out and a new door frame
Edited by stumpy75, 09 May 2019 - 06:22 AM.
#83
Posted 08 May 2019 - 07:56 PM
I know deseaming is not to everyones taste and i dont care to be honest better a modified solid shell built from a scrap tub than another original and rotten mini sat in a scrap yard
Edited by stumpy75, 08 May 2019 - 10:29 PM.
#84
Posted 09 May 2019 - 11:59 AM
Then cleaned up all the joins and holes where i drilled out the spot weldimg
Little bit of deseaming due to a butchered lip and not happy with thd remade lip i mae
Edited by stumpy75, 09 May 2019 - 05:48 PM.
#85
Posted 10 May 2019 - 03:32 PM
#86
Posted 10 May 2019 - 05:04 PM
Today i have cut the floor out as well as the old boxing plate for the a pillar/windscreen surround
The plate behind the join where its deseamed has been seam welded to both panels from inside that baby is going nowhere
I cut out the head rail corner stiffener to get acces to the very top of the backing plate as i didnt want water/condensation getting in behind and causing rot in the future so then a new boxing plate wich i thought was a genuine panel but its very good and cheap to buy so i think well worth time and effort and ime now 110%satisfied that corner is stronger than stock
by the way can you get the header rail stiffener i took mine out as their showin on the schenatic with somerford but ive clicked on it tonight and its no longer available
Edited by stumpy75, 10 May 2019 - 05:41 PM.
#87
Posted 10 May 2019 - 07:39 PM
#88
Posted 10 May 2019 - 10:32 PM
#89
Posted 20 May 2019 - 02:14 PM
#90
Posted 20 May 2019 - 04:24 PM
