What Gearbox Bearing Is This?
engine
Best Answer nicklouse , 25 March 2019 - 03:40 PM
hmm i think you're right. that would be the single roller bearing. phew.
one last question. in the minispares gearbox rebuild kit there are a set of 7 bearings. don't recognise one of them do you happen to know which one it is?
it lists the parts below the picture!
and is the same one as you asked about here
http://www.theminifo...gs-for-rebuild/
Go to the full post
6 replies to this topic
#1 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 25 March 2019 - 02:54 PM
This post is related to my other post on what gearbox bearings to buy, but I figured I'd best post this as a separate question  as that post is a little older now and was assuming I had a 4 synchro gearbox.
I have an A+ engine and (i think) a 4 synchro gearbox, but Im a little confused as I have this gear here that looks like the 2A3709 (1st motion roller for 3 synchro) and also I only count 3 synchros on my partially disassembled main gear set. Basically now Im confused if my gearbox is 3 synchro or 4. I definitely have the 3 step layshaft so it should be the 4 synchro type but this gear here is just confusing me. The 3 synchro roller is extremely expensive and I want to be absolutely sure before i buy it.
here are the pics. maybe someone can recognise what bearing this is.
Note the big nut on the first pic.
Attached File  IMG_20190325_223237.jpg   42.94K   0 downloads
Attached File  IMG_20190325_223253.jpg   34.94K   0 downloads
Attached File  IMG_20190325_223301.jpg   59.38K   0 downloads
#2 nicklouse
  • 18,682 posts
Posted 25 March 2019 - 02:57 PM
number 5?
http://www.minispare...aft.aspx?1~4~38
#3 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 25 March 2019 - 03:04 PM
Attached File  minispares.jpg   112.99K   1 downloads
#4 KTS
KTS
  • 2,457 posts
Posted 25 March 2019 - 03:07 PM
looks like an A+ 4 syncro first motion shaft with the first motion shaft transfer gear still attached.
good luck getting the nut off to - normally it would be undone with the main gear shaft locked in place
#5 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 25 March 2019 - 03:15 PM
i know, thats how i would have done it too, but while i stepped away for a break, my mini guy's assistants decided to continue stripping the gearbox without me and when i came back they had taken most of it apart and that nut was still in place...
im thinking towels and a bench vice to hold the gear in place, and a really long breaker bar...
Edited by BaronVonchesto, 25 March 2019 - 03:15 PM.
#6 nicklouse
  • 18,682 posts
Posted 25 March 2019 - 03:40 PM   Best Answer
#7 BaronVonchesto
BaronVonchesto
  • 515 posts
Posted 25 March 2019 - 04:24 PM
doh i feel like such an imbecile!
thanks
