Going to use my K&N oil and rub stuff
Edited by postve, 23 March 2020 - 07:05 PM.
Posted 23 March 2020 - 04:50 PM
Posted 23 March 2020 - 11:31 PM
From the bottom image up;
1 - right way
2 - wrong way
3 - success
Applause, applause
Speech, speech
I would like to take this time to thank the Mini Gods who have blessed me with a forum willing to listen to
My BS and other ramblings as I stumble through my build. I am forever greatful..
Edited by postve, 23 March 2020 - 11:33 PM.
Posted 24 March 2020 - 12:15 AM
Although I don't always agree with Vizards ideas, I do think that he's correct with regard to full radius ram pipes/stub stacks. The problem with flow bench testing is that it just measures flow, rather than showing where the flow is. If a full radius is preferable, then a full 360deg radius should be better than a 270deg one? You'd need some fancy software to show the flow patterns probably.
Posted 24 March 2020 - 12:54 AM
Edited by postve, 24 March 2020 - 12:55 AM.
Posted 24 March 2020 - 02:32 AM
what is that small KN filter attached to?
Posted 24 March 2020 - 02:42 AM
Edited by postve, 24 March 2020 - 02:43 AM.
Posted 24 March 2020 - 07:52 AM
Thanks Phil, bearing in mind that a full radius is preferable, how much difference do you think it makes when part of that radius is removed as is the case with the MED stub? I suppose a MED stack could have a temporary piece put in to do the comparative test that you mentioned.You don’t necessarily need to see directly where the flow is taking place, simple comparative testing will show this between different designs. Although I’ve actually pulled smoke through my bench as it’s interesting to watch the flow patterns. Until the workshop fills up that is !
Phil.
Posted 24 March 2020 - 08:07 AM
Nick
It's the standard stainless steel housing that it came with - not sure what you are asking for - that in turn attaches to the HIF with typical bolts and washers
I think he means the baby breather style one that is still connected to the carb, possibly to the fuel overflow
Posted 24 March 2020 - 08:13 AM
Nick
Posted 24 March 2020 - 09:14 AM
Nick
Ahh yes Graeme and thx for pointing that out - it is the overflow
Get rid and pipe it away from the carb. You don’t want something like that holding any vapors above the exhaust.
Posted 24 March 2020 - 12:13 PM
Edited by postve, 24 March 2020 - 12:13 PM.
Posted 13 April 2020 - 04:20 AM
Got it and will slap on tonight after work - now that I physically see it, will fit no problem - I hope..
Posted 13 April 2020 - 04:23 AM
Posted 13 April 2020 - 08:11 PM
Not so sure that K&N oil is compatible with foam as its designed for cotton gauze type filters. You might want to check with MED for an answer.
Humm, not sure why it would not but, reason enough to check - thx Croc
Posted 14 April 2020 - 04:02 AM
