New Cones. How High Will I Get?
65 replies to this topic
Poll: Red spot or standard. (28 member(s) have cast votes)
Minispares red spot or standard to replace collapsed cones
  1. Red spot (14 votes [50.00%] - View)
    Percentage of vote: 50.00%
  2. Standard (14 votes [50.00%] - View)
Vote Guests cannot vote
#31 postve
postve
  • 531 posts
Posted 02 October 2020 - 11:14 AM
Well we each have our preferences and I am staying solidly committed to the lowering group although my butt hurts every once in a while.
Thx for the pic Spraybeater I likely will have mine a tad bit lower. Also, I have a ball joint separator fork do I need to get the fancy one with the big screw - what do people use?
#32 Buzzword
Buzzword
  • 72 posts
Posted 02 October 2020 - 01:11 PM
I can't actually remember, which is scary as it wasn't that long ago. I have this type ball joint splitter -
https://www.halfords...cup-695494.html
Works well and doesn't do any damage if you're careful, good addition to the toolbox.
I always just give balljoints a 'tap' or two with a hammer in case it wants to play ball first
#33 postve
postve
  • 531 posts
Posted 02 October 2020 - 03:27 PM
I want to use this with a little tap from ballpeen hammer - should work
#34 leyland73
leyland73
  • 158 posts
Posted 02 October 2020 - 07:38 PM
Ride height from new with ample clearance between the wheel and the arch!
#35 postve
postve
  • 531 posts
Posted 02 October 2020 - 08:26 PM
Too high for me though
#36 postve
postve
  • 531 posts
Posted 12 October 2020 - 03:50 PM
Ok just starting last night as alll parts in will post front and back install as I go along - here's the disassemble part and I was going to use molly grease - stuff I put in nipples when it all goes back in. I went with the red dots
Edited by postve, 12 October 2020 - 03:52 PM.
#37 postve
postve
  • 531 posts
Posted 14 October 2020 - 12:49 AM
Back red dot/new hi lows are in - two finger gap - will test tomorrow and then start fronts
#38 postve
postve
  • 531 posts
Posted 15 October 2020 - 10:11 PM
Here's how it looks with just the rear red dots and new hi lows - I can adjust to suite and the ride is incredible - cannot wait to get the front done - started today I lowered the front to match the new red dots until I swap them out too
Edited by postve, 15 October 2020 - 10:18 PM.
#39 postve
postve
  • 531 posts
Posted 15 October 2020 - 10:16 PM
Now onto the front, passenger side first - nice donut popped right out with no compressor
#40 postve
postve
  • 531 posts
#41 postve
postve
  • 531 posts
Posted 18 October 2020 - 03:24 AM
Ok front is done, now sits a bit higher but I still like it and what a difference in ride and handling - wow!! I will adjust the back again now that fronts are done and take another picture - here's the final drivers side front install - this was not a difficult job by any stretch of the imagination
#42 IronmanG
IronmanG
  • 1,252 posts
  • Local Club: Box hill. Lsmoc member
Posted 18 October 2020 - 07:27 AM
I just measured mine with new cones etc on lowest setting 130mm from top of tyre to arch. It's like a clown car
Edited by IronmanG, 18 October 2020 - 07:28 AM.
#43 postve
postve
  • 531 posts
Posted 18 October 2020 - 12:39 PM
A few more tweaks and I am good as slightly higher than I wanted but will let's the new cones settle a bit
#44 Maccmike8
Maccmike8
  • 1,101 posts
Posted 18 October 2020 - 12:51 PM
The rear height is perfect. Just need to front to settle maybe an inch.
#45 postve
postve
  • 531 posts
Posted 18 October 2020 - 02:16 PM
Without adjustable hi/lows yer screwed as even with those I added 2 inches easy
