Hello all, looking for some help with a charging issue I have with my 1.3 SPi. I've scoured the forums but can't seem to find a solution, although I have learnt a lot!
When running the battery light remains on, but only at about half the brightness that it is with ignition on but engine off. Assuming an undercharging alternator I have:
- Checked earthing circuit between alternator case, chassis, battery negative, engine earth strap (I have a second fitted). All sound
- Checked that belt is tight enough. 12mm on longest length.
- Checked and cleaned condition of alternator wires and connectors at both ends.
- Swapped bulb in battery light.
- At ~2500rpm the alternator output (and battery +ve) give 13.9V
When running the small instrument wire into the alternator is only giving 2.2V not 12. I guess this is providing the voltage across the bulb that is making it light, but why is this voltage low?
I'm now at a loss. I've heard people mention the 'diode pack' within a127 alternators before. Could this be the problem? Where is this located in the alternator, in the rectifier or the regulator?
As an interesting aside, when I drive the car it initially doesn't charge (~11V showing on voltmeter on dash), but after about 5 mins+ this increases to show 13V. Doesn't then seem to change with engine rpm. The engine did however cut out on me whilst braking from 50mph the other day, and that was followed by about 5 mins before the voltage then increased back to 13V. Possibly just something in the 5 minutes of driving just causing a high enough peak in the excitation voltage to get the alternator going?
