It should ground through the alternator with the engine off.
If it doesn't it might be worth checking your earth circuit. Voltage drops between alternator case, engine earth strap and battery negative.
You can also test it isn't the bulb itself by touching the alternator brown/yellow to a bare bit of chassis.
15 replies to this topic
#16
Posted 19 January 2021 - 09:30 AM
Mini Technical Sections →
Problems, Questions and Technical →
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
Auu1086 DizzyStarted by Sharks , 09 Sep 2025 |
Broken Headlight Stalk On InnocentiStarted by IceBlue , 25 Aug 2025 |
