Negative Camber Lower Arm - 3Mm Shim For Bump Stop - Why?
33 replies to this topic
#31 Pete649
Pete649
  • 381 posts
Posted 21 January 2021 - 04:29 PM
30$ ea! Holy Jesus! Are they made of gold?
Plus $40 carriage.
#32 A-Cell
A-Cell
  • 1,610 posts
Posted 21 January 2021 - 07:28 PM
Most of the ones I’ve used barely have 3mm of material to extend the hole into.
Barely is enough though. Even if it ends up in a slot it's good enough to retain the rebound stop.
Avoids having to remove the top arm and modify it.
I have done quie a few like that.
#33 MiNiKiN
MiNiKiN
  • 217 posts
Posted 22 January 2021 - 10:02 AM
I finally have overcome my laziness and took the top arm back out, removed the counternut of the HiLo's, shortened the adjuster bolt and then, after fitting the 3mm-shim to the top arm, putting it all back together worked a treat.
thx for all your feedback
Edited by MiNiKiN, 22 January 2021 - 10:02 AM.
#34 Dusky
Dusky
  • 5,322 posts
Posted 22 January 2021 - 11:24 AM
There is an extended version available in the States, but its quite expensive.
Like these?
https://www.minimani...uffer-Bump-Stop
No, prices of spare parts for minis in the UK are cheaper than cheap
