Bodges Found On Your Mini
45 replies to this topic
#31 mini-mad-mark
mini-mad-mark
  • 926 posts
  • Local Club: northants wot no brakes
Posted 04 May 2022 - 10:43 PM
Oh right - the thread's called bodges found...
Sorry.
Must be my Northampton accent. :blink:
I'm normally good at spotting a pun - especially a current pun.....
#32 Richard_
Richard_
  • 239 posts
  • Local Club: ISMOC
Posted 05 May 2022 - 08:50 AM
:D  :D  :D  like it!
#33 ThrowingTofu
ThrowingTofu
    Just On Tickover
  • 6 posts
Posted 05 May 2022 - 11:18 AM
I'm sure it'll sound familar but i'm busy uncovering a fibreglass coating on all the rust in the boot floor. It looked solid until my battery box almost fell out the bottom of the car.
#34 Bunji81
Bunji81
  • Validating
  • 26 posts
Posted 08 May 2022 - 06:08 PM
No where near as bad as some, but today, I discovered that the inlet and exhaust manifold where held onto cylinder head… finger tight and the previous owner used superglue to hold the cork rocker gasket to the rocker cover…………grrrrr
#35 sonscar
sonscar
  • 3,257 posts
Posted 09 May 2022 - 12:23 PM
Nothing wrong with glueing the gasket to the cover in my book,locates it beautifully,Steve.
#36 mini-mad-mark
mini-mad-mark
  • 926 posts
Posted 09 May 2022 - 08:58 PM
Ii forgot the other one from my project. Blue  Hylomar on both sides of the head gasket ???!!! :ohno:  :mmkay:  :goaway:  :xxx:
#37 sonscar
sonscar
  • 3,257 posts
Posted 10 May 2022 - 07:07 AM
Done that myself,worked for as long as it needed to,Steve..
#38 mini-mad-mark
mini-mad-mark
  • 926 posts
Posted 10 May 2022 - 09:51 PM
Didn't work on mine...... :(
Is it a thing to use sealant on a head gasket? I never have as I thought you weren't supposed to but if it's something I should do then I'm happy to be corrected
#39 Mito
Mito
  • 460 posts
Posted 11 May 2022 - 08:46 PM
Calver st recommend loctite 3020 on the Victor reinz small bore gasket.
#40 Maccmike8
Maccmike8
  • 1,101 posts
Posted 12 May 2022 - 03:20 PM
Mito - Anychance you were Mitoboy on Pistonheads several years ago?
#41 Mito
Mito
  • 460 posts
Posted 14 May 2022 - 04:37 AM
No, that wasn't me.
#42 Eggers
Eggers
  • 57 posts
Posted 13 June 2023 - 09:20 PM
"Hey, you put hinges on with screws, right?"
"Sure"
"Cool."
#43 68+86auto
68+86auto
  • 1,495 posts
Posted 13 June 2023 - 10:42 PM
Seat belt retractor welded on.
Attached File  17_beltl.jpg   40.14K   0 downloads
The car I have worked on with the most dodgy stuff was not a mini and the list is long.
#44 Homersimpson
Homersimpson
  • 851 posts
Posted 13 June 2023 - 11:38 PM
Not on a mini but on an old Jag, how about this piece of filler removed from a wing.  This was only part of it.
This was the hole in the wing after the entire piece of filler had been removed.
#45 MattMini94
MattMini94
  • 46 posts
  • Local Club: London Surrey Mini Owners Club
Posted 14 June 2023 - 04:46 PM
I haven't got any pics but my previous Mini had quite a few bodges, ignition live bodged with stereo speaker wire, then it had a thing where whenever you chucked it around as you do with Mini's 😂 the rear end kept throwing itself out which turned out to be where somebody had snapped
one of the subframe bolts in the back of the heelboard & instead of replacing it just shoved it back in & the best one was when I stripped it down the A post strengthener panel was held on with bathroom sealer. Mini's wouldn't be Mini's if they were perfect 😂
