Posted 03 May 2022 - 07:55 AM
I founded body number C-A2S7-406769A
And Engine number 9F-SA-H23196
I don’t know it real or fake.
Thank you for all answer.
Posted 04 May 2022 - 04:45 AM
9F-SA-H is the correct engine code for a Cooper or Cooper S engine. The number matches in to a similar age to the chassis number from what I can find.
Of course it’s impossible to tell if those numbers match the shell/engine without a lot more information and research.
Posted 04 May 2022 - 06:57 AM
9F-SA is right for an S need to look up the rest of the it for more info.
Posted 04 May 2022 - 12:25 PM
That will be a 997cc Austin Cooper not an S
Posted 05 May 2022 - 07:01 PM
Posted 05 May 2022 - 07:28 PM
What is the exact difference between a Cooper and a Cooper S?
Isn't it Cooper 997/998 and Cooper S 1275!?!
Posted 05 May 2022 - 08:14 PM
I think it is a 1962 - '63 997 Cooper. Very rare car these days as the 998 came in during early 1964 and the 997 was not a good engine.
However, these days a 997 is valuable for reasons of rarity. One in good condition will sell for a lot of money. But before buying, make sure the engine is in good condition with excellent oil pressure, no knocks or rattles, and running well. In particular, check the crankshaft end float and also that it does not blow smoke out of the oil filler cap when it is removed with the engine running at tickover.
Posted 05 May 2022 - 09:18 PM
You could ask the British motor Heritage to get this information,
It costs 6 pounds, but you can ask one question by mail. This is really good to know what is this car.
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
