Trying to set timing but I can't get a signal to the timing light. The car idles at 900rpm with a live constant feed off the fuse box and ground off head bolt. I have tried turning the pickup 180 degrees, moving it closer to the dizzy and on other leads.
Timing light was working a month ago so thought this is odd. I have tried another timing light and this one has a light which lights saying check connection? I do have a spark from ht lead to cylinder 1.
Could it be that the spark/signal is too weak to pickup? or is there something else i can try before buying yet another timing light.......
(1980 mini HL 998)
