1973 Australian Leyland Mini Clubman
50 replies to this topic
#46 68Deluxe
68Deluxe
  • 50 posts
Posted 28 July 2025 - 05:19 AM
You could make a bracket each side to triangulate down to the front subframe bolts. That'd help I reckon.
Coming a long a treat.
#47 Mk2Brett
Mk2Brett
  • 73 posts
Posted 28 July 2025 - 11:07 AM
Got new tyres and wheel alignment done today. It was super sketchy on the 100m drive down the road to the workshop, car was crosseyed the alignment was so bad from my front end upgrades.
Alignment went perfect and it now drives great.
Took it for its maiden drive up to Mount Panorama
Lots more work to do, but its great knowing it can be back on the road now at least!
Little lap around Mt Panorama Bathurst
https://youtu.be/bE8...eL9UmAHDJR5d5S7
#48 timmy850
timmy850
  • 3,594 posts
  • Local Club: MITG
Posted 28 July 2025 - 08:48 PM
Are you going to the Rylstone classic this year? Or even just the Sunday - lots of minis going from Rylstone to Bathurst for a few laps
#49 Mk2Brett
Mk2Brett
  • 73 posts
Posted 29 July 2025 - 12:15 AM
Yeah thats the plan, hoping we make it to Rylestone!
#50 Mk2Brett
Mk2Brett
  • 73 posts
Posted 02 August 2025 - 12:51 PM
I took the Mini to an exhaust shop to get an O2 sensor adapter welded into the exhaust. When it got up on the hoist, it was leaking fuel from the metal fuel pipe, it had a tiny pin hole that was leaking fuel at pretty decent rate.
I ended up cutting that section of pipe out, and patching it with some 1/4" fuel host and clamps to get it home. Once home I replaced the front to back rusted fuel pipe with some new rubber fuel hose
Makes me feel a lot better now that all the old metal lines (brakes + fuel) have now been replaced.
Since I had to switch back to the old rocker cover, added an ST sticker
Fit the boot liner in and now it looks great
As a side project, Since I used new radius arms on this Mini, I started refurbing the old ones to have as spares. They were covered in a rubberized under coating that needed an hour of grinding and wire wheeling to clean off
Will strip the rest of the rust off and then prime and rebuild them for spares.
For the rest of the week will be doing final preps to try and get to car to Rylestone
#51 Mk2Brett
Mk2Brett
  • 73 posts
Posted 10 August 2025 - 10:55 AM
We made it to the Rylstone Classic!
All the prep and rebuild over the last few months was worth it and the Mini made it all the way there and back without any issues.
(Well we did blow a fuse pulling out of Worthington Mini Garage but that was a quick fix)
There is still more work we will be doing but it will likely progress at a more leisurely pace now that the big event has passed.
Here are some photos from the trip
530007513-10161601949798807-645802123059
530641663-10161601949273807-632839287369
530992094-10161601949083807-833400882984
531019998-10161601949358807-376333855721
And finally, the photo at Rylestone!
