Hi all,
Looking for some help to identify some wires in the boot of my 93 Rio. I did look on the wiring diagram, but could not see to spot it
Images can be seen here https://imgur.com/a/zgyVD46
Thank you
Posted 11 July 2025 - 04:13 PM
Hi all,
Thank you
Posted 11 July 2025 - 05:59 PM
What are the colours of the wires ?
Posted 11 July 2025 - 07:13 PM
Wire 1 connector has a blue with a black stripe and the other being blue with a white stripe
Wire 2 has a purple/ plum colour with a light pink stripe
Wire 3 has two connectors. First connector has a black wire. The second connector has two cables both being blue with a green/lime stripe
I hope that helps describe them better. I do have a link to the imgur album.
Happy to perform checks or provide more pictures to help
Posted 11 July 2025 - 08:03 PM
Posted 11 July 2025 - 08:16 PM
A 'base' colour Blue is a Headlamp Wire. Blue /Black is from a fuse block to the Right Hand Headlamp - not a colour used in a Mini !
Blue / White if Main or High Beam
What these are doing in the boot ??? I'd say someone has done some home handyman wiring here, or they could be for an after-market Sound System.
Purple / Pink is rear window heater.
Black is Earth
Blue / Green is headlamp washer pump
Posted 11 July 2025 - 09:07 PM
Black is Earth
Wire 1 coming from above the fuel tank does seem to be audio related as there is an after market system.
Sorry, but what do you mean by headlamp washer pump? I know there is a blue green stripe cable in the boot on the driver side, but this is located on the passenger side with two cables going into the male bullet plug
Thank you for helping me figure out wire 2, the rear window heater and black being earth
Posted 12 July 2025 - 12:58 AM
In the later cars, they did have a washer pump in the boot, I can't recall if that was for windscreen or headlamps (or if it did both), but I was just working from the colour codes and Rovers standard colours and that's what it comes up as.
Posted 12 July 2025 - 05:52 PM
Edited by cal844, 12 July 2025 - 05:52 PM.
Posted 13 July 2025 - 08:37 PM
Posted 29 July 2025 - 04:49 PM
Wire 2 in my Rio is not connected to anything just like yours.
It’s not for the rear window heater, as that’s green and yellow on the passenger side, and black on the driver’s side on my Rio.
Not sure what this wire is for to be honest, as I can’t see anything that it connects too on my car.
Interesting. I will have to have to trace the wire. What does your Wire 1 and Wire 3 connect to?
Posted 01 August 2025 - 09:03 PM
I will have a check tomorrow and let you know.
Posted 03 August 2025 - 10:26 AM
The single bullets black and blue/yellow will be rear fog light both RHD or LHD.
single spade purple will be alarm boot switch
The pair of blue wires is rear speaker
Mini Technical Sections →
Problems, Questions and Technical →
Broken Headlight Stalk On InnocentiStarted by IceBlue , Yesterday, 09:59 AM ![]() |
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1987 Mini Rover Fuel Gauge IssueStarted by kwfranky , 11 Jun 2025 ![]() |
