Bau1962Ms Distributor
46 replies to this topic
#1 gaspen
gaspen
  • 1,194 posts
Posted 06 December 2025 - 08:55 AM
Hello
Could someone confirm if this dizzy has a high energy modul in it or not ?
Should I run it with a 3 ohm or lower resistance coil ?
DISTRIBUTOR 45D ELECTRONIC pre A PLUS NEG EARTH ONLY - Mini Spares
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 06 December 2025 - 01:21 PM
Use that with a coil resistance of 1.4ohm minimum. 3 ohm coils should not be used with any variable dwell dizzy. If you want to run the Higher power version you need to look at the EVo versions.
Ac
Edited by ACDodd, 06 December 2025 - 01:21 PM.
#3 gaspen
gaspen
  • 1,194 posts
Posted 06 December 2025 - 05:08 PM
Ac
Thanks AC
I learnt from your video that a white dot means LE module but I couldn't decide that there is a dot on mine or a "patch"  :D
It has the same modul that they put in PowerSpark dizzys ? Maybe the dizzy is equal to PowerSpark's top entry electronic version ? (D4-98)
Could I benefit anything with a HE modul on my very standard 998 A-series ?
Attached File  20251206_110306.jpg   50.81K   3 downloads
Edited by gaspen, 06 December 2025 - 05:12 PM.
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 06 December 2025 - 07:56 PM
Every engine runs better with high energy.
That's the low energy version.
Ac
#5 gaspen
gaspen
  • 1,194 posts
Posted 07 December 2025 - 07:52 AM
Ac
I see, thanks
So I should choose one of these, right ? Ballast Ignition Coils - Powerspark Ignition
Maybe you know which curve GEU930MS has ?
Edited by gaspen, 07 December 2025 - 10:40 AM.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 07 December 2025 - 10:50 AM
If it were my car I would change the module to a higher power one and recurve the dizzy you already have.
Then fit a Viper VCE coil. There is a reason I curve my own dizzies, and that's because I can get consistent curves.
Use heatsink compound under the module when fitting the new one. Set the reluctor air gap to 0.5mm.
https://simonbbc.com...search_query=M5
https://simonbbc.com...earch_query=Vce
Ac
Edited by ACDodd, 07 December 2025 - 10:53 AM.
#7 gaspen
gaspen
  • 1,194 posts
Posted 07 December 2025 - 11:01 AM
Ac
This is exactly what my plan is  :proud:
Actually I've made a "distributor machine", it looks BAU192MS is equal to a 41418 curve
#8 68+86auto
68+86auto
  • 1,477 posts
Posted 07 December 2025 - 12:50 PM
Ac
Did you notice the high rpm retard which occurs on inductive ignition systems?
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 07 December 2025 - 01:23 PM
These powerspark units are magnetic pulse driven, not Hall effect.
Ac
#10 68+86auto
68+86auto
  • 1,477 posts
Posted 08 December 2025 - 04:32 AM
Ac
Inductive means magnetic. Hall effect doesn't have the retard but I still choose to use inductive (magnetic). The level of retard varies depending on the module as well as the pickup gap.
Edited by 68+86auto, 08 December 2025 - 04:33 AM.
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 08 December 2025 - 03:26 PM
This is not evident with the powerspark units.
Ac
#12 gaspen
gaspen
  • 1,194 posts
Posted 08 December 2025 - 09:08 PM
My friend found this "old" 45D in his garage. The rectangular "trigger" is secured on the shaft with a pin.
Without the white dot how could we determine if it is a high or low energy unit ?
(I hope the link work as I unable to attach picture)
https://photos.app.g...hmCoy5RckpiW119
#13 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 08 December 2025 - 09:42 PM
You run a 0.8ohm coil, if it fails it was not rated for
It.
Ac
#14 gaspen
gaspen
  • 1,194 posts
Posted 07 January 2026 - 03:45 PM
Some graphs for the 998.
Black : factory 41418
Yellow : igntion123  'A' curve
Blue : 1st BAU1962MS  (in this one the springs were NOT manipulated  by the manufacturer)
Red : 2nd BAU1962MS (the springs were manipulated)
Attached File  Képkivágás.JPG   44.58K   6 downloads
#15 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 07 January 2026 - 05:16 PM
None of them are that useful, the secondary spring is too tight.
Ac
