Bau1962Ms Distributor
46 replies to this topic
#31 68+86auto
68+86auto
  • 1,477 posts
Posted 18 January 2026 - 12:45 PM
Not that chinese junk  O_O
https://photos.app.g...HCHBB2ot2FsVmf6
There's always something new to surprise me.
#32 gaspen
gaspen
  • 1,194 posts
Posted 18 January 2026 - 02:42 PM
Problem solved
Attached File  20260117_103719.jpg   25.95K   1 downloads
The full advance issue still annoys me.
Out of the box the dizzy has almost 20 degrees advance (see picture) With some welding I set it to 11 degrees but on my dizzy machine it makes ~8 degrees - even  with only one light primary spring installed.
Attached File  20260111_141114.jpg   37.81K   0 downloads
#33 gaspen
gaspen
  • 1,194 posts
Posted 18 January 2026 - 05:53 PM
I've found some more chinese-style machining which could affect the operation
The upper half of the cam had a small shoulder inside where the fixing screw's washer sits. Until now I thought that it was "tight" because of the 2nd spring force, but no : the cam get stuck at "high" degrees when the screw is tightened. I removed that shoulder with Dremel, now it's fine
Attached File  20260118_161138.jpg   49.99K   0 downloads
Another remark is the position of the reluctor. On my unit it sits a bit lower compared to the module, on my friend's unit it is on the same height. (This one has that very low dwell value)
The cams are almost the same except that bevel on mine.
Does that height difference affect anything ?
Attached File  20260118_164430.jpg   70.42K   0 downloads
Attached File  20260118_164448.jpg   64.37K   1 downloads
Attached File  20260118_170127.jpg   62.52K   1 downloads
#34 68+86auto
68+86auto
  • 1,477 posts
Posted 19 January 2026 - 05:41 AM
Yes I imagine that would lower the voltage the pickup outputs and therefore change the dwell or timing.
I was never satisfied with the return of the advance mechanism on the distributor like that which I have. Maybe that is why. There is normally an allowance of about 2° difference between the decelerate and acceleration curves. It was well over 2°.
Now imagine all those people who just throw in a distributor without careful inspection. New must mean good right?
There's a reason they are cheap. No seller has some magic trick to make a distributor better than the competitors for the same price.
#35 gaspen
gaspen
  • 1,194 posts
Posted 19 January 2026 - 07:23 AM
And that is why Minispares don't respond to my complaint about the faulty module  :goaway:
Now I am thinking that renew an old dizzy with an electronic module would be a better idea....
On the other hand my GEU930 for the 850 works nicely (on the test bench at least)
Edited by gaspen, 19 January 2026 - 09:24 AM.
#36 68+86auto
68+86auto
  • 1,477 posts
Posted 19 January 2026 - 10:54 AM
I have been buying all the 59DM4s and 45DM4s that I can find at reasonable prices. I wish there was a better solution. I have at times considered modifying non-Lucas distributors but new distributors of all brands have the same problems. I have been curiously waiting for Bestek to release his ones.
I wonder what the new 65DM4s are like since they are a different design.
Edited by 68+86auto, 19 January 2026 - 10:56 AM.
#37 gaspen
gaspen
  • 1,194 posts
Posted 31 January 2026 - 09:45 AM
We bought a new Powerspark high energy module for my friend's distributor. I've put it in, took it to the dizzy machine and it shows the same values as the previous module which we thought faulty.
Should the high energy module has less dwell value compared to the low energy?
#38 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 31 January 2026 - 01:38 PM
Are you testing it with a 0.8ohm coil?
Ac
#39 gaspen
gaspen
  • 1,194 posts
Posted 31 January 2026 - 04:05 PM
Ac
No, but now as you asked I realized what's the "problem"
In my other topic Spider suggested to install 2 Ohm resistance for "dummy coil" to my machine for testing electronic units. I guess 2 Ohm is too much for a high energy module.
Distributor Machine - Page 9 - Mini Chat - The Mini Forum
#40 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 31 January 2026 - 07:35 PM
If you want to test things is needs to be tested running the correct loads or you likely won't see the responses your looking for.
Ac
#41 68+86auto
68+86auto
  • 1,477 posts
Posted 01 February 2026 - 03:18 AM
IF you want to see the dwell as it would be on the car, you'll need to run close to the same resistance. With the wrong resistance the dwell is still an indication of the modules function, it just won't be the same as on the car.
The resistor in my distributor machine is quite high (can't remember the value). The machine was made that way and specified as being able to do high energy ignition systems. The dwell simply runs as high as possible.
#42 gaspen
gaspen
  • 1,194 posts
Posted 01 February 2026 - 08:27 AM
Thank you, now it is clear
But it's still interesting as BAU1962MS should NOT have a high energy module
Anyway I'll setup the curve and we will check in the car with 0.8 coil
#43 gaspen
gaspen
  • 1,194 posts
Posted 01 February 2026 - 11:39 AM
What is your opinion on this red curve ?
Std. 998cc A-series
Attached File  Képkivágás.JPG   41.39K   2 downloads
Edited by gaspen, 01 February 2026 - 05:31 PM.
#44 ACDodd
ACDodd
  • Mini Docs
  • 2,836 posts
Posted 01 February 2026 - 07:31 PM
Install at 28degrees at 4000rpm.
Maybe a touch long would be better with 8'degrees at idle.
Ac
#45 gaspen
gaspen
  • 1,194 posts
Posted 01 February 2026 - 08:26 PM
Ac
You mean decrease the total advance by 3 crank degrees?
Oh I forgot : I will install stage 1 kit and the manual suggests 5 degrees at 1000 rpm.
It looks fine with this setup, isn't it ?
Also I tested the another high-energy module dizzy with 0,8 ohm coil and it has nice dwell readings
Edited by gaspen, 01 February 2026 - 08:53 PM.
