None of them are that useful, the secondary spring is too tight.
Ac
Thanks ![]()
Posted 08 January 2026 - 07:31 AM
Ac
Thanks ![]()
Posted 13 January 2026 - 01:49 PM
Is it possible that the strength of both springs won't allow full advance ?
On this unit I mesured almost 20 degrees with protactor, but only 13 on the machine.
I welded up for 11, now I measure 8 on the machine
20260113_135623.jpg 38.97K
2 downloads
Posted 13 January 2026 - 08:16 PM
Posted 14 January 2026 - 12:13 AM
Can you put up the test results?
Posted 14 January 2026 - 09:43 AM
Yes, here they are. The red graph shows the test results. The black is one from CSI curves which with a little mod, which I think that should be good for the std. 998.
As I said before I have two of these dizzys.
BAU1962/A is my friend's unit
BAU192/B is mine after some "tuning".
The pictures shows the dwell values at 500 (left) and 3000 (right) dizzy rpm. What causes the difference ?
bau_bali.JPG 24.18K
3 downloads
BAU_Beni.JPG 24.37K
3 downloads
dwell_bali.jpg 53.58K
6 downloads
dwell_beni.jpg 49.97K
5 downloads
Posted 15 January 2026 - 12:41 AM
Are these hall effect or inductive?
Posted 15 January 2026 - 08:23 AM
Inductive
Posted 15 January 2026 - 12:55 PM
Posted 15 January 2026 - 02:15 PM
Dwell looks much to short on the second dizzy, try a replacement module.
Ac
You mean the 1st one? Dwell is where the ligth is OFF
Posted 15 January 2026 - 07:11 PM
Posted 15 January 2026 - 07:27 PM
Yes I understand, the dwell looks much too short.
Ac
I am confused ![]()
Unit A : 8 degrees dwell on ~500, 22 d's ~3000 (distributor rpm)
Unit B : 22 / 50 degrees
I think unit A is faulty, isn't it ?
Posted 15 January 2026 - 07:58 PM
Posted 16 January 2026 - 10:32 AM
Posted 16 January 2026 - 04:48 PM
I wondered why there was a brass blade on my set of feelers.
