Ecco Vs Facet
27 replies to this topic
#16 PACINO
PACINO
  • 821 posts
Posted 04 September 2026 - 12:41 AM
I have Ecco pumps on 2 minis at present and will be fitting another when the mechanical pump packs up on my wife's mini. They are the correct pressure for a mini, if you buy the right model. It acts exactly like an SU Pump, only ticking when the fuel pressure drops. I believe they are pos or neg earth and come complete with mounting bracket etc.
A New Zealand product which I know is used on Morris Minors. MGB's etc. think they're on the Fuelsave website, where you can see the various models available.
I recommend them. (hopefully I'll get a parcel in the post after this)!
Have you tested the pressure?
No. these are the ones I use. 2 - 3 psi. https://simonbbc.com...Ss10amEhL5xj6fC
One  is on a 1293 with 80bhp and the other is on my 1098 with 78 bhp. Absolutely no problem with float valves or modern fuels.
That ECCO fuel pump model is exactly the one I was looking at yesterday. It delivers between 2 and 3 psi, which is precisely what a twin SU HS2 carburetor setup requires. Therefore, installing a pressure regulator might not be necessary, as it won't flood the carburetor float chambers.
Whistler, would you be so kind as to tell me what place have the ECCO pumps installed in your cars?
Many thanks in advance!
Kind regards
Original location on rear subframe, on both cars.
Cheers man !
#17 PACINO
PACINO
  • 821 posts
Posted 04 September 2026 - 12:59 AM
That is the ecco that I have.
I find it peaks at 4.5psi and the pressure then drops due to the needle leaking.
Even the manufacturer now says 4psi: https://fuelflow2020.nz/?page_id=188
4.5psi?? The specifications say;"Operating Pressure(Psi) 2 – 3 psi". Are you using a regulator of pressure friend? And your carburettor is?
#18 Steam
Steam
  • 965 posts
  • Local Club: Victorian Mini Club
Posted 04 September 2026 - 01:08 AM
I have a facet on 2 cars and a cheap ebay special (hep 02a) on another, the cheap pump performs just as well as the facets, will draw from the engine bay and is quieter.
Edited by Steam, 04 September 2026 - 01:11 AM.
#19 68+86auto
68+86auto
  • 1,497 posts
Posted 04 September 2026 - 06:40 AM
No regulator, HS4. I'm sure I could get better economy with lower pressure.
If you look the the manufacturer's current website, this is what you'll see:
Attached File  Screenshot_20260904_163824_Opera.jpg   23.22K   0 downloads
#20 whistler
whistler
  • 1,903 posts
Posted 04 September 2026 - 11:17 AM
Scroll down to the spec list and it states 2-3psi. Can't see that 1 psi makes any real difference especially as the pump is not operating all the time like a facet.
#21 68+86auto
68+86auto
  • 1,497 posts
Posted 05 September 2026 - 09:09 AM
I believe what happened is the manufacturer used to specify 2-3psi and that is the description most sellers are still using. The Website I linked to is the current manufacturer's website so should be the most accurate (they have gone through a few different websites in recent years).
When talking about 3psi, 1.5psi is a BIG difference. Especially when 3psi is already on the high side of what is ideal. That is why so many people have been fitting fuel pressure regulators.
#22 68+86auto
68+86auto
  • 1,497 posts
Posted 05 September 2026 - 11:11 AM
A new discovery of mine is that the ecco will slide out of it's bracket if you drive on rough roads.
#23 PACINO
PACINO
  • 821 posts
Posted 09 September 2026 - 10:31 PM
Well, that seems to have an easy fix. The question is: is it a noisy pump?
#24 whistler
whistler
  • 1,903 posts
Posted 10 September 2026 - 09:15 AM
No, can't hear it except from ignition turn on. The Ecco pumps I've fitted have not moved at all.
#25 68+86auto
68+86auto
  • 1,497 posts
Posted 10 September 2026 - 11:47 AM
I have never heard it running. Seems silent to me.
I doubt anyone else would have the same rough road problem as me unless you go driving on opal mining fields.
#26 68+86auto
68+86auto
  • 1,497 posts
Posted 10 September 2026 - 11:56 AM
Attached File  IMG_20260910_215027_(1080_x_800_pixel).jpg   67.55K   0 downloads
I only pushed this in a couple of days ago. Now I doubt many people will have the same problem but I do see it as a poor design.
Attached File  IMG_20260910_215412_(900_x_1200_pixel).jpg   44.91K   0 downloads
#27 PACINO
PACINO
  • 821 posts
Posted 14 September 2026 - 02:46 PM
Beautiful! That's what I wanted to hear. Thanks for your opinion.
#28 PACINO
PACINO
  • 821 posts
Posted 14 September 2026 - 02:52 PM
Cheers man! You're very kind
