My Sprite Pocket Rocket
109 replies to this topic
#91 neil_g
neil_g
  • 880 posts
Posted 02 August 2006 - 03:23 PM
thanks timothy :)
oh and the timing cover is off now too for i have a plan, i said i wasnt going to do much with the engine but ive had a bit of a change of heart. but im keeping it under my hat for the moment.
plus found a thread stripped out holding the tranfer case to the block, bum.
just wish i had more spare cash and time to get the project rolling quicker..
#92 neil_g
neil_g
  • 880 posts
Posted 09 August 2006 - 07:40 AM
mock-up time (scuse the mobile phone pics)...
the 20 degree layback might be a problem, i cant reach the handbrake that well but i have a plan for that. plus i might need to switch to an internal mounted gear selector.
on the other hand the seat is suprisingly comfortable, sat in it for a good 30 mins the other night while browsing some parts catalogues with no numbness in site.
been pondering about selling my bolt in cage and getting an SD weld in jobbie?
Edited by neil_g, 09 August 2006 - 07:42 AM.
#93 dougie_10 :D
dougie_10 :D
  • 447 posts
  • Local Club: The Mini Forum
Posted 09 August 2006 - 09:58 AM
the seat looks so uncomfortable lol But actually they aren't bad at all as I sat in a friends mini when he had it and had those seats.
As to the bracket situation I dont know for sure but I would imagine you'd have to bend it to the old shaped one :w00t:
#94 neil_g
neil_g
  • 880 posts
Posted 09 August 2006 - 12:35 PM
edit: removed, no longer applies.
Edited by neil_g, 02 October 2006 - 01:10 PM.
#95 neil_g
neil_g
  • 880 posts
Posted 02 October 2006 - 01:10 PM
small update, was in the garage for an hour or so yesterday..
cam and timing chain removed, both not going back in. the kent MD286 will probably be replaced by something like a 300 and the standard cast duplex chain will be replaced by a lightweight vernier.
next step is taking the pistons/rods and crank out for machining. then its a bare block which is going for a clean up and a few bits of work:
* chemical clean
* block drilled for 11 stud head
* threaded oil gallery plugs
* 4 bolt center main strap
* re-tap thread on block (above pic, middle bolt on the bottom of pic) whoever bolted the clutch housing on last must of stripped the threads out
still not entirely sure which direction to go with the head, will probably end up ebaying this one and getting something better, maybe from Longmans (if i sell my arse).
thats about it for the mo..
#96 dougie_10 :D
dougie_10 :D
  • 447 posts
Posted 02 October 2006 - 02:50 PM
Looks like you have been busy then.
Great stuff mate :gimme:
#97 miniman/nico
miniman/nico
  • 64 posts
  • Local Club: tmf
Posted 08 October 2006 - 10:39 AM
aup neil i noticed in one of your pics you have a elecrtic fan what did you get it off ? as im looking for one myself cheers nico.
#98 MiniDude
MiniDude
  • 96 posts
  • Local Club: Birmingham
Posted 08 October 2006 - 12:07 PM
Coming along nicely! Like the kirkey seat, mental things they are! :D
#99 mad4mins
mad4mins
  • 1,396 posts
  • Local Club: WAMO!
Posted 10 October 2006 - 11:58 AM
never seen those doors before! they look fantastic....
how much weight do you reckon you save??
nice seats too..
keep on posting!!
#100 neil_g
neil_g
  • 880 posts
Posted 17 October 2006 - 02:06 PM
good news bad news situation..
good news, ive finally got the block completely stripped bar cam bearings which needs to be done professionally using specialist tools.
however.. there seems to be some serious scuffing down the skirt on a couple of pistons. so i need to check for excessive wear on the pistons and the bores otherwise its time for a rebore (up to 74mm 1400cc) and new pistons. joy.
otherwise, took the gearbox/diff casing apart (leaving gearset inside) and gave it a nice clean ready for a new coat of paint.
sorry about the pic quality, ive stopped taking the DSLR out in the garage.
ooh, questions.. where did they come from??!
miniman/nico - the only leccy fan i have is the late rover standard item?
mad4mins - as much as possible without taking huge chunks out of the body..
#101 miniman/nico
miniman/nico
  • 64 posts
  • Local Club: tmf
Posted 25 October 2006 - 11:15 PM
ahhh right my 998cc mini has the elecy fan hole there i just need to buy one to put in lol :genius:
#102 neil_g
neil_g
  • 880 posts
Posted 05 February 2007 - 02:39 PM
small update:
gearbox has a fresh coat of paint and is back together with new gaskets and a magnetic pick up filter. slightly let down by old bolts though.
*rubbish phone pics alert*
also arrived in the post:
1x new scuttle panel
1x new top dash rail
1x floor x-member
#103 cubby
cubby
    Starting My Mini Up
  • 3 posts
  • Local Club: non but will join one eventually
Posted 06 February 2007 - 11:47 AM
this project is awsome really insired me to get my hands on a mini asap and get stripping it
nice one mate
keep us updated,
cubby
#104 miniallsort
miniallsort
  • 4,723 posts
Posted 06 February 2007 - 12:05 PM
wow looks great dude
#105 neil_g
neil_g
  • 880 posts
Posted 06 February 2007 - 01:38 PM
thanks for the comments guys..
hopefully now we've finally bought a place i should have a bit more time to give to the project :(
