quick resto
#31
Posted 12 April 2007 - 12:05 AM
thursday before easter long weekend got the floor tacked in place,
friday welded in place from the inside and cut the O/S sill off then bought a wire wheel for the angle grinder, did some more cutting out with it TO MY HAND gona have nice scar there now
saturday i did nothign due to my hand
sunday did some cutting out of holes the jacking point on the sill sorka kinda came off! i dont like using them any how so just gona weld over the hole in the sill, welded in a patch on the sill then roun out of gas doh!
Monday, got more gas welded up the rest of the sill! not bad going for sumone who almost ground to the bone (i guess a td over exagurate) anyway when i hammerited it over still need to weld the sill on
today got some fuel out of herb and put it into clubby and runs again damn i though the fuel gauge was inacurate! needs setting up yes but oh well
its hard explaining things without pics, i shall do a better write up tomorrow with piccys
#32
Posted 16 April 2007 - 10:46 AM
Passenger floor showing a few patches that need to be done
Showing near side sill been welded in place and ground down
And in Hammerite!!! much better than before
The much sexy Maniflow system!!!
The 1100 engine, with Hif carb and Maniflow system fitted
Drivers floor all cut out
And the new floor! much more solid than before
Off side sill removed, looking rather grotty!!
Bad looking hole
little hole in N/S rear passenger floor
The view from the rear pocket
Patch at the driver area sill. The jacking point wasnt secure at all and i wasnt willing for anyone to try it so off it came and another patch in place
The rear sill bit patched up
Hammerited inner sill
Bit dark, but its the sill tacked in place (has now been full welded just i forgot piccys
Drivers wheel arch, kinda roughly welded because i ran out of gas
Driver wheel ll done and Hammerited!
#33
Posted 16 April 2007 - 07:08 PM
i also patched up the passenger floor mostly, just gotta seam weld around one patch
Things to do...that O/S rear passenger hole, its been welded from outside just i want to do inside aswell
After all weldings done ill be booking the rolling road session and MOT
the all the grinding starts and then dress the welds with seam sealer, hammerite then underseal
interior to go in them and should be about done.....i hope...
anyway just a few things playing on my mind, in the future its gona need a respray, now the colour is super rare now iv only ever seen 1 the same on here, but im also not to keen on it so wondering if i should stop being a girl and put up with it or choose a nice blue or somthing? any ideas hints welcome
Edited by mini93, 16 April 2007 - 07:16 PM.
#34
Posted 18 April 2007 - 08:59 PM
got home from work today rung up southam mini and metro centre, the earliest apointment for RR they had was for the 30th at 3pm, i then rung local MOT place and booked in for the 1st
so its kinda cutting it fine, i need to car done by friday because thats when i go away for the riviera run eep! so im gona let the garage to the fix's (depending anyway)
after that was booked i went to knick the rear seats out my white mini which im going to recover to match
then ground down the welds on the drivers floor and put seam seeler on...looking much neater
Edited by mini93, 18 April 2007 - 09:00 PM.
#35
Posted 19 April 2007 - 11:09 AM
Well you should stop being a girl for a start... people might start to wonder
I don't know bout the colour I'd rather see it in real life. But I'm tempted to say put up with it.... likely to change my mind though! LOL!
#36
Posted 19 April 2007 - 04:21 PM
colour, its just too, non-racerish which is what i was always like with my white mini, im gona request a photoshop, one with the blue and one with my colour, both will have the wheels i have on herb and wood and picket arches
hopfully will give me more of an idea
#37
Posted 23 April 2007 - 12:24 AM
fitted the interior yesterday, minus carpets and front doorcars anyway, leaving the carpets out till i have ground the underside im not risking fire
also fitted the wheels off herb, my white mini
fitted the front grille, bumper and lights again and god does it look sooooo much better!!!
also from when i cut thru the brake lines i found the union in the pressure regulating valve was ceased and i FINALY got it out today, woo mole grips shame they destroyed the union, ill go to southam tomorrow after work i hope, then get on with re-piping it
i was going to grind the welds on the underside just i fell sick and couldnt bring myself to do anything GRR!!!!
what do people think then?? does it look ok? still needs adjusting in places grill isnt sitting right quite yet but its about there
#38
Posted 23 April 2007 - 06:09 PM
#39
Posted 23 April 2007 - 08:32 PM
anyway, today after work i went straght to southam mini and metro centre to get a brake union because the head was destroey trying to take the old one out, got home using string measured the length i needed to cut and started laying the pipe....internaly woo!
anyway yep, layed the pipe down and connected the unions, there not tight at the mo because my tools are at work and also not fluid filled ill do that on the weekend when i have some help, and my tools back from work
#40
Posted 23 April 2007 - 10:05 PM
#41
Posted 27 April 2007 - 11:44 PM
tightened up the brake lines, tried beeding but i messed tha up doh! so gotta wait till sunday till mike can come round give me a hand
anyway also fully chopped off the rear valance, ground it down to place. have to weld up both corners, just little patching to be done, nothignt bad. iv already done 1 corner
anyway all the stuff that needs to be done this weekend.
go to min-its get lower engine mount bush's
weld the back edge of the driver floor (bit inside exhaust tunnel)
weld the little patch on passenger floor
weld rear valance in place
weld pipe line stays
grind the welds on the underside of the floor
dress the welds on the underside
paint interior floor
place rest of the interior in
paint underside floor and waxoil
fit engine steady
bleed brakes
BOTTOM HOSE (cant keep forgettin this)
oh CRAAAAAP quite a bit to do
Edited by mini93, 28 April 2007 - 12:12 AM.
#42
Posted 28 April 2007 - 12:12 AM
Second thoughts - I'm pretty useless...
Lookin' good though, David!
#43
Posted 28 April 2007 - 12:15 AM
mini was on the drive because i hate layng down on stones so i yoinked it!
#44
Posted 28 April 2007 - 11:26 PM
weld rear valance in place very almost done
paint underside floor (wax oil at later date)
fit engine steady
bleed brakes
weld battery cable stays
bottom hose was just stupid to do, the clip was ceased so i had to remove the radiator, and then i still coudlnt get it off so i had to saw the clip
took 4 trips to halfords for parts lol, they think im wierd
eerm welding inside the exhaust tunnel was acward aswell, but thats done, i wont be able to grind there i shouldnt think so ill just put seam sealer or fiberglass past over the welds to neaten them up
#45
Posted 29 April 2007 - 11:54 PM
fit engine steady
bleed brakes
hard work today, not very good in some, but good in others
i started the day doing the valance, and had done that in a lil over an hour, then i ground down the welds on the O/S sill and seelered it
i went helfrauds for a tow rope, i got one of those heavy duty elasticated ones as i dont trust my mum soo much
anyway when i got back mike (pikey7) was there to help me with the brakes, so we started doing that, and bled them, just there was hardly any pressure build up, i would get pressure right at the bottom of the travel and then its not very much, i would pump the brake and more pressure would build up
this pissed me off, we messed about with this for ages, and its suspected master cylinder seal >
so anyway, after mike went i got on with grinding the driver floor, i then seeled that aswell
tried bleeding the brakes again to no avail
so i moved onto the N/S sill and floor so i ground that down, and seeled that up, also seeled the driver floor in the exhaust tunnel....pain in the arse i say! but not as bad as welding it
so then its getting dark, and i put the interior in, and it looks really nice
anyway things for tomorrow
fit engine steady
seal the exhaust
fit door cards
smooth valance lip and paint up
fit bumper
re-fit bonnet
make up some rear bin shelf's and fit
all before the MOT thats at 8am tuesday
oh and its insured from the 1st with all mods declared
just gotta hope the log book turns up before friday so i can get tax to drive to newquay
