The KAD rebuild thread......
637 replies to this topic
#136 not so mini dan
not so mini dan
  • 374 posts
  • Local Club: NA
Posted 10 May 2007 - 07:40 PM
Any updates on the project Dan?
#137 danwebster
danwebster
  • 637 posts
Posted 10 May 2007 - 08:06 PM
Progress is slow this week, with the weather being so bad i've done nothing to the shell. I've taken my head in to be skimmed to get my compression through the roof though, I should be picking that up tomorrow so the engine build will start very soon.
#138 danwebster
danwebster
  • 637 posts
Posted 11 May 2007 - 04:47 PM
Well today things have gained some speed.....I have stripped the front end of the car completely, subframe and suspension off.....did I mention that this particular subframe won't be going back on the car either....?
Got the head back from skimming and CC'd it, you may already know that 10thou on a 73.5mm bore is worth 1cc....with the combustion chamber being the shape it is 10thou off the head should be worth a bit less than 1cc, so I asked for 20thou off the head as I was trying to lose around 1.5cc from the total chamber volume......well I lost 2.5cc! which means my compression ratio will be 13.1:1.....or in other words extremely bloody high!!!
My cometic head gasket came through the post today too so I now have everything I require to reassemble the engine.....yeehaa!
#139 supermotolee
supermotolee
  • 1,120 posts
Posted 11 May 2007 - 06:09 PM
might have to run it on av gas at this rate haha...
#140 danwebster
danwebster
  • 637 posts
Posted 11 May 2007 - 06:12 PM
Yeah we looked into that before funnily enough, theres a place near me I can get it from....
#141 not so mini dan
not so mini dan
  • 374 posts
  • Local Club: NA
Posted 12 May 2007 - 08:03 PM
I cant remember if you were running throttle bodies or not, yes or no? >_<
#142 danwebster
danwebster
  • 637 posts
Posted 12 May 2007 - 08:07 PM
Twin 40's - webers >_<
#143 fastcarl
fastcarl
  • 344 posts
Posted 12 May 2007 - 09:23 PM
Webbers, but they are so last melenium!!!.lol. you really need to move into the twenty whatever it is century Dan.
go NOS, effy , and turb.
#144 danwebster
danwebster
  • 637 posts
Posted 12 May 2007 - 09:25 PM
But I like the noise they make carl.....
I can't afford all that trickery anyway, not after getting the car back!
#145 not so mini dan
not so mini dan
  • 374 posts
  • Local Club: NA
Posted 12 May 2007 - 10:01 PM
Go for some Jenvey ITBs and a Mega Squirt management system, that way you can have different maps for different fuel grades (ooooooo Bioethanol!)
#146 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 12 May 2007 - 11:28 PM
webers may be last mellenium, but theres no better noise, love it >_<
#147 danwebster
danwebster
  • 637 posts
Posted 13 May 2007 - 09:42 AM
I'll be running it on a mapped ignition, just not fuel injection.
#148 danwebster
danwebster
  • 637 posts
Posted 13 May 2007 - 05:45 PM
Just made a windage tray for the gearbox, its almost finished.....just need to drill and tap the other side (where the oil pickup pipe normally fixes) so I can fix it down at that end, and add some drain holes I think.
#149 AlexF2003
AlexF2003
    Ring Runner 2005
  • 383 posts
Posted 13 May 2007 - 05:50 PM
looks good matey!
I think you should run it on MJ for the ign >_<
#150 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 13 May 2007 - 06:55 PM
are you not covering the final drive and diff up with the windage tray too?? surely having half the engine running with the weight of oil on it is worse than all of it!
