hif44 fitting problems
20 replies to this topic
#16 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 30 March 2007 - 08:02 PM
Okay, the bottom pipe is the one for the fuel inlet, the two top pipes are easily identified by the size the larger one is the breather and the smaller of the two is the fuel over flow. Help that helps?
Pete.
#17 Gazman
Gazman
  • 148 posts
Posted 30 March 2007 - 08:10 PM
Ok, still look for the pics though....that'd be cool.
Have a look at my other post and tell me where each number should go in post #9
http://www.theminifo...showtopic=44320
#18 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 30 March 2007 - 09:49 PM
okay, here's how it is on mine, I wandered outside in my socks with a torch for you!!
1. Petrol overflow pipe.
2. Pipe connected to clutch housing breather. (metro only)
3. Fuel inlet
4. Blanked off.
5. Vacuum pipe to dizzy.
#19 Gazman
Gazman
  • 148 posts
Posted 31 March 2007 - 09:11 PM
thanks gazman sounds like your having exactly the same trouble, you had any luck sorting it yet?
Sorted mine now. Turned out the HT leads were on the wrong connectors. It would appear that all the advice and Haynes manuals were wrong. I moved mine all anticlockwise one connector and it fired first time!
#20 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 31 March 2007 - 09:37 PM
I think you will find that the Haynes manual is not wrong but rather that the person who set up the disrtibutor timing did not follow an accepted 'correct' procedure. This leads the the confusion. If they had followed clearly set out procedures, that the majority of people follow as a general rule, you would not have had a problem :-
Some one always has to do something differently :goaway:
#21 Gazman
Gazman
  • 148 posts
Posted 01 April 2007 - 10:41 AM
Fair enough...just for the record it weren't me!!
