999cc Twincam 16v
#31
Posted 03 May 2007 - 05:40 PM
the reason why is if that IS as 16v then why have a 8v cam cover? Or more importantly why go to the lengths and expense of having one cast when you can wled an oil filler on to the 16v cover easily.
Secondly there is no engine brake in any of those videos, or similar set up meaning that the you cant get a true figure. Also the lap top could be linked to anything.
to be honest with you this has all been outed before on Turbo minis.
#32
Posted 03 May 2007 - 05:50 PM
#33
Posted 03 May 2007 - 07:02 PM
nice little engine though - just not as it says on the label
Johnk
#34
Posted 03 May 2007 - 07:52 PM
#35
Posted 04 May 2007 - 08:18 AM
Simon
#36
Posted 04 May 2007 - 08:22 AM
If I was paying that much for an engine I would expect a half decent rocker cover on it, dont forget its in a race series as well so Morspeed want they're logo prominently on the engine
#37
Posted 04 May 2007 - 08:36 AM
#38
Posted 04 May 2007 - 08:40 AM
im confussed how can it be a 999cc if u used a 1275 block or did u sleave the bores ?also whats decking it ? is that skimming ?
Decking is when you take (skim) an amount of the top of the block, that combined with a different crank stroke can give you 998 iirc but is expensive to achieve.
I think doing it that way gives you short stroke action though which is good
#39
Posted 04 May 2007 - 08:47 AM
#40
Posted 04 May 2007 - 09:01 AM
#41
Posted 04 May 2007 - 09:43 AM
I would imagine there are fail safes and cut offs to cut the engine in the event of a problem. That being said I don't think you'd need screens up to protect yourself, you wouldn't put up a protective screen between you and a running engine in a car would you?is it me or is there no safety protection whilst the motor is being used? I couldnt see any screen protecting the people sat at the laptop, ruddy sure I woudlnt be sat there!!
Simon
#42
Posted 04 May 2007 - 09:45 AM
Simon
Like a bulkhead ?
#43
Posted 04 May 2007 - 09:46 AM
#44
Posted 04 May 2007 - 10:04 AM
#45
Posted 04 May 2007 - 12:22 PM
