I've had my mini on the road since March this year ('07) and since then have had the wheels refurbed and many other bits and bobs sorted on it. Now that I've just begun to build a performance engine for it, it was a good point to start recording my progress!
Below it the beast as it stands.
Engine
-MG Metro 1275 (Dished Pistons, Leaded 10.5:1CR)
-HIF44 Single Carb
-Stage 1 Kit (Playmini Centre Exit Exhaust, K&N Cone Induction)
-Stage 2 Unleaded Head (Larger valves and sharpened inlet ports)
-Metro Elecronic Ignition
-Central Oil Pick Up Pipe
-Braided Flexible Block To Oil Filter Hose
-Coil Relocated To Bulkhead
Exterior
Respray Shell to 'JCB' Orange with black roof
Black Group 2 Arches
Black Handles & Bumpers
Black Mini Special Grille With Relocated Number Plate
Headlight Stone Guards
Twin Fuel Tanks
Interior
Stripped 'Rally Style' (No Sound-proofing!)
6 Point Roll Cage
Custom Dash & Wiring Loom Inc. Starter Button & Fusebox/Headlight Relays Relocated Onto Dash
Black Cobra Buckets with 3 Point Harnesses
Internal Battery Feed
RH Fuel Tank Isolation Tap
Wheels, Tyres & Suspention
12" Wolfrace Elf Alloys, Falken Tyres
Fully Adjustable SPAX Coil Overs All Round (Lowered height at front, standard height at rear)
I've recently taken it for a Sprint event organised by the RAF. It was my first time on track and I thouroughly enjoyed it. In the morning session, I managed to beat an XR2 fiesta, Mk1 MR2 and A-series Metro! I didn't fare so well in the afternoon due to my slightly gearbox struggling to change from 3rd to 2nd at speed, but did jump up to the next group.
I've decided that I'd like a little more power and so have recently invested in a 1293 block and pistons, intenting to build my own performance engine. As you can see I have already made a start and fitted a low milage crank with new bearings. The pistons I bought with the block are brand new, but low compression so I have just sourced another set from eBay for under £50 which should give me a better compression ratio. When they arrive I'll be able to check what condition they're in. I'm intending on fitting a hotter cam than the standard MG Metro I'm currently using, along with my stage 2 head. Other mods may be included, funds depending. I'd like a lightened flywheel too!
Reet, I think that's enough for now! Phew!
